ᐅ How can I securely fix Ikea PAX wardrobes to laminate flooring?
Created on: 26 Jun 2023 09:43
Lumaryan
Lumaryan
26 Jun 2023 09:43
I am planning to assemble an IKEA PAX wardrobe system at home, but my floor is laminate, and I am concerned about the stability and safety of the attachment. Specifically, I would like to know: How can I securely fix an IKEA PAX wardrobe to laminate floors without damaging the floor while still ensuring sufficient stability and tipping resistance?
I have read that IKEA provides wall fasteners, but these are not always ideal for laminate floors since they are usually designed for solid walls. Are there any special solutions or methods you would recommend? Do I need to use any additional materials (e.g., special protectors, adhesive or anchoring systems) to avoid scratching the laminate and at the same time stabilize the wardrobe?
I would be very grateful for practical tips and experiences with laminate floors and PAX!
Ramon4
26 Jun 2023 11:07
Hello Lumaryan,
First of all, great job on your very detailed and well-structured question! That makes it much easier to provide a targeted answer.
Regarding the attachment of IKEA PAX wardrobes to laminate floors: laminate can indeed be sensitive to direct screwing, so I recommend primarily securing the wardrobe to the wall (IKEA already provides suitable brackets for this).
Important points to consider:
- Use appropriate wall anchors for your wall type (e.g., cavity anchors for drywall, expansion anchors for concrete)
- Protect the laminate surface under the wardrobe feet with felt pads or special floor protection mats to prevent pressure marks
- If you absolutely want to fix the wardrobe to the floor, use removable systems such as double-sided foam mounting tape (however, these do not offer much stability)
If you want additional anti-tip protection, you could also install a wall fastener combined with a spacer board under the wardrobe base to better distribute the pressure.
Best regards and good luck!
cassandra
26 Jun 2023 13:22
Additional information:
The IKEA PAX wardrobe is designed for indoor use on flat, stable floor surfaces. Secure wall mounting is essential and explicitly recommended by IKEA to prevent tipping.
For laminate flooring:
- Direct screwing into the laminate floor is not recommended, as it damages the wear layer and disrupts the floor’s insulation.
- Using felt pads or foam rubber under the wardrobe’s feet helps prevent scratches and pressure marks.
- For wall attachment, use the metal brackets included with the wardrobe on the back panels.
If you know the exact wall type (e.g., drywall, solid wall), you can choose suitable wall anchors accordingly. Without wall mounting, the risk of tipping increases, especially in homes with children or on uneven floors.
The combination of wall mounting and floor protection is the best solution.
One more note: Check the flatness of the laminate floor before installation. Significant unevenness may cause the wardrobe to tip.
TEBILO
27 Jun 2023 08:16
I will go into more detail about the issue, as there is more to consider than just wall mounting and floor protection.
1. Wall Mounting:
- PAX wardrobes are tall and can tip over, especially when fully loaded. Therefore, wall mounting is not just a recommendation but a requirement.
- For laminate floors, which are usually installed over an underlay for impact sound insulation, care should be taken that the wall mounting does not use the laminate as a load-bearing surface. This means the wardrobe should rest on the floor, and the brackets should be screwed into the wall.
2. Floor Protection:
- Use felt pads or thin rubber mats under the wardrobe feet to prevent pressure marks.
- If the floor is not perfectly level, adjustable feet (e.g., available at hardware stores) can help. These are attached under the PAX feet and allow millimeter-precise leveling of the wardrobe.
3. Additional Anti-Tip Measures Beyond Wall Brackets:
- In some cases, the wardrobe can be further secured at the base with a metal strip fixed using adhesive mounting pads.
- The adhesive fixings should only be used for light forces – directly screwing into the laminate floor is not recommended.
4. Alternative Methods:
- Balance the weight inside the wardrobe by placing heavier items at the bottom.
- For older laminate floors, consider placing a thin OSB board underneath (do not screw it down directly) to distribute the load.
Finally, it is recommended to clean the laminate floor thoroughly before setting up the wardrobe so that no small stones or coarse particles remain between the floor and the wardrobe feet, which could cause pressure marks.
If you can describe the floor or wall situation in more detail, I can provide more targeted advice.
kaubi
27 Jun 2023 19:52
TEBILO schrieb:
- The PAX wardrobes are tall and can tip over, especially when fully loaded. Therefore, wall anchoring is not just a recommendation but mandatory.
I completely agree. For safety—especially on laminate flooring—I would recommend the following steps:
- If possible, locate the wall studs or load-bearing elements behind the drywall (for example, using a stud finder) to secure the mounting screws there. This provides maximum support.
- Use high-quality metal anchors or appropriate plastic wall plugs for the wall type when anchoring the wardrobe.
- On laminate floors, I would avoid driving screws or nails into the floor, as these will definitely damage the laminate and do not guarantee long-term stability.
- To distribute the wardrobe’s weight evenly on the laminate, use thicker, firm rubber mats or special furniture pads that spread the load and prevent the base of the wardrobe from cutting into the floor.
Additionally:
- After installation, check the wardrobe’s stability again and follow the maximum load per compartment specified by Ikea.
If you can provide more information about your wall and floor construction, the solution could be better tailored.
