ᐅ How can I securely fasten Ikea Pax wardrobes to drywall without losing adhesion?
Created on: 25 Mar 2019 08:32
Z
Zarkmin
I am currently facing the challenge of securely attaching my Ikea Pax wardrobe to a drywall (gypsum board) wall. It is especially important to me that the mounting is not only stable but also does not compromise the adhesion of the drywall panels. Given the weight of the wardrobe and daily use, I want to ensure there is no risk of pullout or damage.
My drywall consists of a double layer on a timber stud frame, but the studs are not consistently placed everywhere, so I cannot always screw directly into a stud. Therefore, I am looking for ways to securely anchor the Ikea Pax without jeopardizing the wall’s load-bearing capacity. The solutions should take both the drywall material and construction into account and not reduce the adhesion of the gypsum boards.
Does anyone have experience with special anchors, reinforcements, or installation techniques? Are there professional methods that can be applied by DIYers? I look forward to your advice and tips!
Zarkmin schrieb:
I am considering installing a horizontal batten but am unsure how to securely attach it to the wall and whether it might even affect the entire wall structure.Hello Zarkmin,
To securely install a horizontal batten, the most important requirement is to screw it into the existing wooden studs. Since you have a stud every 60 cm (24 inches), you should position the batten so that it can be fastened to at least two studs. Key points to consider:
- Use 5 x 60 mm (5/16 x 2 3/8 inch) wood screws (or longer) to ensure at least 4 cm (1 5/8 inch) penetration into the stud.
- Pre-drilling can help prevent the wood from splitting.
- If the construction allows, you might also glue and nail the battens.
Once the horizontal batten is securely installed, the load of your Pax will be distributed much better compared to direct fixing with anchors. Then mount the cabinet on the batten using heavy-duty screws or suitable furniture brackets.
Important:
- Before drilling, check that there are no cables or pipes behind the wall.
- When drilling into drywall (gypsum board), always use a low speed and light pressure to avoid damaging the panels prematurely.
By following these steps, the adhesion of the drywall should not be compromised, as the load will act as a line load on the studs and battens rather than a point load.
I would like to add the following:
When installing on drywall (plasterboard), it is advisable not to screw directly into the drywall itself but to ensure you hit the wooden stud behind it. For mounting posts on a drywall partition, I usually use a combination of drywall screws and wood screws.
If access to the other side of the wall is possible, additional reinforcements can potentially be installed behind the wall.
In summary: secure mounting requires load distribution and close contact with the supporting wood.
If you like, I can provide you with detailed instructions on how to install such a crossbeam.
LENNAU schrieb:
If you want, I can write you a detailed guide for installing such a cross batten.That would be great. A step-by-step guide for installing cross battens specifically for double-layer drywall would definitely help many others here as well.
As a reminder to Zarkmin: Make sure to protect the wall from any stresses during the work (for example, avoid sharp edges damaging the drywall panels) and check the stability again with gentle pressure after installation.
Additionally, the batten structure should be designed to systematically transfer loads to the wooden subframe without creating weak points. Sometimes, it’s also a good opportunity to install appropriately sized supports at the ceiling or floor if the wall alone seems too weak.
