ᐅ How can I securely attach IKEA Metod kitchen cabinets to walls in older buildings?
Created on: 12 Feb 2021 10:23
sefoki
sefoki
12 Feb 2021 10:23
I am currently facing the challenge of securely mounting IKEA Metod kitchen cabinets to the walls of an older building. The walls are made of older masonry, some are load-bearing, some are not, and they are often uneven. My question is: What is the best way to attach IKEA Metod upper and lower cabinets to these types of older walls to ensure a stable and long-lasting installation?
Specifically, I am looking for advice on suitable wall plugs, screws, and possibly preparatory steps like leveling the wall surfaces or reinforcing the walls. How do you approach installation when the walls consist of different materials or have irregularities?
Thank you for your experiences and tips!
theo63
12 Feb 2021 12:47
sefoki schrieb:
How can IKEA Metod kitchen wall cabinets and base cabinets be best mounted on old building walls to ensure a stable and durable construction?
This is indeed a tricky question, as old building walls can vary greatly. Generally, I would say: there is no one-size-fits-all solution—you first need to accurately determine the wall material.
- Are the walls solid brick or natural stone, or are they more like timber frame with clay or gypsum plaster?
- Are the walls load-bearing or just partition walls?
Only with this information can you select the appropriate fastening materials.
Additionally, the load-bearing capacity of the substrate should be tested: drill tests and plug trials can be revealing. For older, crumbling walls, I would be cautious with expansion anchors or standard wall plugs. Heavy-duty anchors or using plugs in specially drilled holes might be necessary.
It should also be considered that IKEA Metod cabinets are designed with a cross-screw mechanism and relative connection between cabinets—the main load should be supported by a sturdy mounting rail or bracket that distributes the weight pressure evenly over the surface.
In short: without a precise wall analysis, there is no safe installation. Therefore, I recommend a multi-step approach, including a make-or-break test with impact anchors and wall testing.
Naomige
12 Feb 2021 15:11
theo63 schrieb:
You cannot assume a one-size-fits-all solution; you first need to determine the wall material precisely.
I completely agree and would like to suggest a more systematic approach here that also works well for less experienced DIYers:
1. Check the wall condition: Distinguish between solid masonry (brick, concrete) and lighter walls (e.g., plaster on wooden battens).
2. For solid walls, I recommend using hammer-in anchors or chemical anchors combined with standard screws. These provide very strong support.
3. For crumbly or uneven walls, mounting rails are a good option. These can be fixed to the best possible surface with longer screws before installing the kitchen cabinets. The cabinets then hang from these rails, which helps distribute the load more effectively.
4. For drywall or thin wall constructions, an additional reinforcement behind the wall may be advisable, such as a wide wooden frame anchored inside the wall.
5. Never rely on a single anchor point to carry the load. Use multiple anchors to spread the load evenly.
As always: drill carefully to avoid damaging brick elements, and choose anchors with the correct size.
I hope this helps as a first step!
nanidra
13 Feb 2021 09:02
Naomige schrieb:
For crumbly or uneven walls, mounting strips are recommended. These can be attached before installing the kitchen using longer screws on the most solid surface available.
A mounting strip is standard, but honestly: that doesn’t solve the underlying problem if the wall itself is weak or uneven. You can hardly give the strips a stable hold if the surface underneath doesn’t support it.
Therefore, I generally question whether it might be better to fully prepare the old wall for kitchen installation using modern fastening methods, such as a substructure made of solid wooden beams anchored into the masonry columns at appropriate points.
theo63 schrieb:
No secure installation without a precise wall analysis.
That’s true, but it is often neglected. In the end, the cabinet still comes loose.
I advocate using less conventional, specialized solutions in older buildings. It might also be worth consulting a structural engineer if load-bearing walls are involved.
Alternatively, you could take a completely different approach and install freestanding kitchen units that rest on the floor instead of relying solely on wall mounting.
Garry
14 Feb 2021 17:36
nanidra schrieb:
I advocate using less conventional, specialized solutions for older buildings. It might also be worth consulting a structural engineer when dealing with load-bearing walls.
That’s a wise suggestion. I’d like to add from my experience: The following method has proven effective for attaching IKEA Metod kitchens to walls in older buildings:
- First, install a mounting batten, such as a planed spruce batten measuring 40x60 mm (1.6x2.4 inches) or similar. Ideally, secure this with heavy-duty anchors or impact dowels into stable masonry.
- For uneven or mixed wall surfaces, level out irregularities beforehand using drywall panels or leveling mortar to prevent unnecessary stress on cabinets caused by warping.
- Important: Use chemical anchors for porous or sandy old walls, as these provide significantly better holding strength.
- IKEA wall cabinets already come with hooks for the mounting batten, which makes installation easier and ensures load capacity.
A structural assessment is generally not necessary for private kitchen installations but is recommended for very unstable walls or historic buildings.
In general, patience during wall preparation is crucial.
