ᐅ How can I securely fasten IKEA Metod kitchen cabinets to drywall (plasterboard) walls?
Created on: 23 Aug 2020 18:27
Pusilas
Pusilas
23 Aug 2020 18:27
I am currently planning to install IKEA Metod kitchen cabinets in my rental apartment, where the walls are made of drywall. I want to secure the cabinets very firmly to the wall because, on the one hand, the weight of the kitchen units should not be underestimated, and on the other hand, the wall cabinets will be additionally loaded with items such as plates, pots, or even heavier kitchen tools.
My question is: How exactly can IKEA Metod kitchen cabinets be securely mounted on drywall without damaging the wall or making the cabinets unsafe? What kind of mounting hardware is suitable? Are regular wall plugs sufficient, or should special toggle anchors or perhaps wooden battens be screwed behind the drywall?
Has anyone had experience with this and can share advice on how to best distribute the load? I want to avoid unsightly damage to the wall but also not worry about the cabinets eventually falling down. Thanks for your help!
stefangla
23 Aug 2020 19:34
Hello Pusilas,
First of all: drywall (gypsum board) walls are not designed to support heavy loads by themselves. This means that without additional measures, you won’t achieve the full load-bearing capacity that solid walls provide.
For securely mounting your IKEA Metod kitchen cabinets, please consider the following:
- Check whether there is a load-bearing frame made of wood or metal studs behind the drywall – in these areas, you can screw directly into the studs using long screws.
- If no suitable load-bearing substructure is available, you should use heavy-duty anchors, such as metal expansion anchors (wall anchors) or special drywall anchors with high holding strength.
- Another proven method is to attach a thick wooden batten (e.g., a laminated wood panel) to the wall, either using heavy-duty anchors or fastening it into the studs, and then mount the cabinets onto this batten. This way, the weight is distributed more effectively.
A common mistake is relying solely on drywall anchors, as these often cannot reliably support the weight of a complete kitchen cabinet.
My advice:
- Use at least heavy-duty anchors with a diameter of 10–12 mm (0.4–0.5 inches).
- Use a stud finder or an endoscope to ensure that no substructure is present.
- If possible, add extra reinforcement with wooden battens or metal profiles behind the drywall.
In summary: attach directly to drywall only using special metal expansion anchors or similar, but preferably anchor through to a wood or metal substructure.
If you need more details, feel free to ask!
Kabau
23 Aug 2020 20:06
stefangla schrieb:
Drywall panels are naturally not designed to support heavy loads.
Exactly, that’s why you should always locate the load-bearing studs and attach the cabinets there.
- Metal expansion anchors for lighter loads
- Wooden batten as a load distributor when access to studs is limited
This is usually sufficient.
Grace
24 Aug 2020 08:12
Hello Pusilas,
I would like to add from experience that drywall (gypsum board) walls can flex and absorb loads to some extent—but not indefinitely.
Regarding your project: IKEA Metod kitchen cabinets are quite heavy, especially when fully loaded. Therefore, standard drywall anchors are often not a suitable solution for hanging cabinets.
As stefangla already mentioned, you should try to anchor the fasteners into the wall studs. If the studs are unfortunately positioned inconveniently, installing a sturdy mounting board (for example, a 15 mm (5/8 inch) OSB panel) across the entire horizontal length of the cabinet row can help.
You then screw this panel directly into the drywall framing using heavy-duty anchors or long screws, ideally fastening into wooden or metal studs. The cabinets are then attached to this panel. This way, the load is distributed and point loads on the drywall panels are avoided.
Important:
- Avoid using drywall anchors for the main load, as they are intended more for lightweight pictures, shelves, or lamps.
- Use appropriate mounting boards to increase load-bearing capacity and minimize installation errors.
If possible, carefully test the stability after installation before fully loading the cabinets.
I wish you much success—it really pays off to invest enough time and care in fastening.
