ᐅ How can I securely attach IKEA Metod kitchen cabinets to drywall (gypsum board) walls?
Created on: 9 Mar 2024 18:07
KOBEDRI1
KOBEDRI1
9 Mar 2024 18:07
Hello everyone, I have a question about securely attaching IKEA Metod kitchen cabinets to drywall. Since the Metod cabinet units are quite heavy, I’m unsure whether they can simply be fixed with standard wall plugs in drywall or if special measures are necessary. Can someone explain how to install the cabinets so they remain stable and secure on a drywall surface in the long term, possibly considering reinforcements or alternative support systems? I would appreciate advice on choosing the right anchors, drilling techniques, and load distribution. Thanks in advance!
andre3
9 Mar 2024 18:39
When attaching IKEA Metod kitchen cabinets to drywall, the load-bearing capacity of the material is crucial. Drywall alone does not reliably support the weight—especially with fully loaded kitchen cabinets. The most common and secure method is to fix the cabinet mounts to the underlying wooden studs or metal framing.
Alternatively, if direct fastening to the substructure is not possible, special drywall anchors designed for high loads, such as toggle bolts or hollow wall anchors, should be used. The following points should be considered:
- Anchors must be rated for the weight of the cabinets including their contents
- Using multiple anchors helps distribute the load more effectively
- Utilizing the IKEA Metod mounting rails for better load distribution
Important: Check whether there is a load-bearing substructure behind the wall to screw into.
kaubi
9 Mar 2024 19:12
I am happy to add more detailed information to andre3’s points:
- First, use a stud finder to precisely locate the studs, either wooden frames or metal profiles, behind the drywall. This is essential because you can screw directly into the structure at these points with suitable fasteners.
- For fastening to wooden studs, I prefer wood screws of appropriate length, at least 6 x 60 mm (¼ x 2 ½ inches), depending on the wall thickness. For metal profiles, special self-drilling metal screws are required.
- If no studs are found, high-quality drywall anchors should be used—for example, toggle bolts or spring toggle anchors that fold and expand behind the drywall. I would recommend installing at least four to five anchors per cabinet to ensure the load is well distributed.
- Another option for maximum security: attach a reinforcement panel made of OSB or multiplex board behind the drywall. This panel is firmly screwed to the wall, and the kitchen cabinets are then mounted on it, distributing the load over a larger area.
Please note that Metod wall cabinets must be mounted significantly more securely than decorative shelves due to the high weight of fully loaded cabinets.
nojaus
9 Mar 2024 20:03
I understand that this topic can seem a bit intimidating. Especially if you have no experience with drywall walls and the kitchen furniture is very valuable, you want to avoid making any mistakes. From my own experience: patience during planning and careful mounting really pay off. I myself had long considered whether to add extra reinforcements because I was afraid someone might later load the compartment too heavily and everything would slip down.
My advice: with drywall, always make sure not to rely on a single fixing point to carry the load. And if you are unsure, it’s better to consult a professional. It’s worth preventing damage to both the kitchen and the wall.
kasan
9 Mar 2024 21:18
[@andre3, post: y6k0l6, member: XXX]
I generally agree with this, but I would like to question the assumption that hollow wall anchors or expansion anchors are always sufficient. The load from fully loaded kitchen cabinets is considerable, especially when they are frequently opened and closed. The cyclical load also significantly increases the risk of failure.
If no sturdy stud is available, in my opinion, reinforcement should be considered, for example with a prefabricated support panel behind the drywall. This is the only way to safely handle permanent loads.
Without such measures, I believe there is a risk of damage to the wall and ultimately unsafe installations. Relying solely on heavy-duty hollow wall anchors seems too risky to me. Documentation or experience reports showing long-term reliability would be interesting.
INGRID34
10 Mar 2024 08:02
For fastening:
- Locate studs behind drywall
- Screw directly into studs
- Do not hang heavy loads on hollow wall anchors alone
- Possibly use an OSB board for reinforcement
That is basically sufficient.
