ᐅ How can I securely attach IKEA Metod kitchen cabinets to brick walls?
Created on: 20 Feb 2023 09:14
SofarHello everyone,
I am currently planning to mount my Ikea Metod kitchen cabinets on a solid brick wall and want to ensure that the fixings are truly permanent and secure. My wall is made of solid brick with no plaster or insulation, and I have read that it is important to choose the right anchors and screws, as well as to distribute the load evenly.
Specifically, I am wondering which type of anchors (e.g., expansion anchors, hammer-in anchors, or chemical anchors) are best suited, whether I should place the screws directly into the bricks or into the mortar joints, and what the best approach is to prevent damage or loosening of the wall cabinets.
Are there any special tips or recommendations regarding wall preparation, the tools to use, or the installation process to mount the kitchen cabinets optimally? I would appreciate any practical experiences or well-founded advice, especially from those who have installed kitchens on brick walls.
Thanks in advance!
Thanks in advance!
For securely mounting IKEA Metod kitchen cabinets to brick walls, I recommend the following approach:
- Use high-quality hammer anchors or, even better, chemical anchors (injection mortar), as these provide excellent holding power in solid brick.
- Screws should preferably not be placed in the mortar joints, as these are usually not load-bearing enough; the drill holes should be made in the brick itself.
- Pre-drilling with a suitable masonry drill bit, matched to the anchor size, is essential to ensure the anchor holds properly.
- When installing, make sure the loads are evenly distributed by using multiple fixing points across the entire width of the cabinets.
- Check the screw length so that it anchors deeply enough into the plug to ensure full load capacity.
Tools: Cordless drill driver with hammer drill function, masonry drill bit, spirit level, screwdriver.
This method is proven and safe for Metod kitchens on untreated brick walls.
I would also recommend chemical anchors. They are a bit more expensive but provide significantly better hold than traditional expansion anchors in brick.
They are usually used with an injection mortar that fills the hole completely, distributing the load more effectively.
Also: Do not drill into the mortar joints, but directly into the brick. The joints are often too weak.
The most important thing: Use a hammer drill function to prevent dust from remaining in the hole.
pikin schrieb:
Screws should preferably not be placed in the mortar joints, as these are usually not strong enough; the drill holes should be made into the brick itself.This statement is absolutely correct and essential! I would like to clarify it further, as brick walls can vary significantly depending on quality and color.
- First rule: always drill into the solid brick, never into the joint.
- Second rule: clean, deep drilling using a diamond or carbide masonry drill bit.
- Cleaning the hole—a frequently overlooked step—is often a common source of errors: dust residue inside the hole greatly weakens the hold. It’s best to clean it with a small round brush or a vacuum cleaner.
Regarding anchors, I can confirm: chemical anchors perform better under load, especially with dynamic stresses like opening and closing doors.
Not only is the choice important, but also the installation:
- It’s best to mark all fixing points and measure precisely to distribute the weight across multiple anchors.
- Always pre-drill with a masonry drill bit that is at least as long as the anchor.
One small tip: if you use flexible screws (for example, round head screws), hanging the Metod cabinets may be easier—and future adjustments simpler.
Have you already chosen a model? How wide are the cabinets? Then I can give you more specific recommendations regarding the anchors.
kulau schrieb:
Have you already chosen a model? How wide are the cabinets? Then I can give you more specific recommendations for the anchors.Thank you for the detailed post! The cabinets are mostly 60 cm (24 inches) wide, mainly wall cabinets ranging from 40 to 60 cm (16 to 24 inches) in width, with a total of about 4 to 5 units on the wall.
The brick wall is unfinished, with no additional plaster layers or insulation. That poses a challenge for me because I want to avoid the brick chipping or cracking when drilling.
I would like to know if, besides chemical anchors and a hammer drill, there are any specific precautions I should take when drilling to prevent damage to the brick? Are there recommended drilling speeds or techniques to protect the brick?
Also, what is the minimum recommended distance between anchors to ensure optimal stability? Thanks!
When drilling into a brick wall, always start at a low speed and activate the hammer function.
Increase the speed once the hole is properly positioned. This helps prevent chipping on the surface.
Keep a distance of at least 30 cm (12 inches), preferably 40 cm (16 inches), between wall plugs to distribute the load evenly.
Chemical anchors are strong when installed correctly – follow the manufacturer’s instructions regarding curing time.
Also, do not use screws that are too short to ensure a secure fastening.
