ᐅ How can I securely attach IKEA Metod kitchen cabinets to brick walls?
Created on: 20 Feb 2023 09:14
Sofar
I am currently planning to mount my Ikea Metod kitchen cabinets on a solid brick wall and want to ensure that the fixings are truly permanent and secure. My wall is made of solid brick with no plaster or insulation, and I have read that it is important to choose the right anchors and screws, as well as to distribute the load evenly.
Specifically, I am wondering which type of anchors (e.g., expansion anchors, hammer-in anchors, or chemical anchors) are best suited, whether I should place the screws directly into the bricks or into the mortar joints, and what the best approach is to prevent damage or loosening of the wall cabinets.
Are there any special tips or recommendations regarding wall preparation, the tools to use, or the installation process to mount the kitchen cabinets optimally? I would appreciate any practical experiences or well-founded advice, especially from those who have installed kitchens on brick walls.
Thanks in advance!
parnar
22 Feb 2023 07:52
Sofar schrieb:
I am interested to know if, besides using chemical anchors and a hammer drill, there are specific precautions to take when drilling to avoid damaging the brick? Are there recommended drill speeds or techniques to protect the masonry?
I think it’s great that you’re paying close attention to the correct drilling method! If you drill carefully with steady pressure and an appropriately low speed, you can do this easily.
Take breaks from time to time to prevent the drill bit from overheating. It also helps to start by positioning the drill bit gently on the spot and beginning carefully—this will help avoid chipping.
Your project sounds excellent, and with the right approach, your Metod kitchen cabinets will be mounted securely. Good luck!
