Hello everyone, I am currently faced with the task of securely mounting my new IKEA Hemnes shelves to the wall and have a detailed question about this: What installation methods are recommended specifically for the Hemnes series to ensure maximum support and stability? I am particularly interested in which types of anchors and screws are suitable in combination with different wall types (e.g., concrete, drywall, brick). Are there any special precautions or accessories from IKEA or hardware stores that should definitely be used to safely install the shelves and prevent tipping? Additionally, what is the best positioning of the brackets in relation to the load? I look forward to well-founded and practical advice, including any personal experiences!
Hello Attispau, regarding your question: With Hemnes shelves, it is especially important to use the supplied wall anchors and to secure them properly to the wall. Generally speaking:
- For concrete walls, be sure to use appropriate hammer-in anchors, which help ensure a secure hold.
- For drywall, you should definitely use special hollow wall anchors to firmly fix the screws.
- Brick walls work well with plastic wall plugs that lock into the drilled holes.
Keep in mind that the shelf brackets should always be installed near wall studs or load-bearing elements. This significantly increases stability. Hemnes shelves often have pre-drilled holes to help locate the exact fastening points – these are positioned intentionally.
It is also important not to overload the shelves and to distribute the weight evenly. If you plan to place heavy items, it is recommended to add additional support in the center underneath the shelf.
If you can provide more details about your wall type, I’d be happy to offer more specific advice.
Hello Attispau, I’m happy to provide you with a simple step-by-step guide for the safe installation of the Hemnes shelves:
1. Determine the wall type: concrete, brick, drywall—this is crucial for selecting the right anchor.
2. Choose the anchor type: for example, expansion anchors for concrete, hollow wall anchors with metal threads for drywall.
3. Mark the bracket positions: ideally on wall studs or load-bearing substructures.
4. Pre-drill holes: use a drill bit that matches the anchor size exactly—neither larger nor smaller—to ensure a secure hold.
5. Fix the brackets: screw in the fasteners with the correct torque, securing the furniture supports carefully.
6. Set up the shelf and check: make sure the shelf is firmly installed and does not wobble.
Common mistakes include:
- Using anchors unsuitable for the wall type
- Mounting brackets only on drywall without reinforcement
- Overloading the shelves
Additionally, note that some Hemnes models have a safety fixture or a second bracket in the middle. If available, use these for better stability. Always follow the assembly instructions provided with Hemnes, which also include recommendations for appropriate accessories. If installing the shelf in a rental property, it may be helpful to inspect the wall more closely beforehand, for example with a stud finder.
In summary: plan carefully, use the right anchors, install precisely, and consider the load capacity.
Genevieve26 Nov 2022 15:47Takutau schrieb:
Note that shelf brackets should always be installed near wall studs or load-bearing elements. That is good advice, but in everyday situations it is often difficult to follow, especially with older or uneven walls. I would recommend checking beforehand with a proper stud finder or wall scanner to confirm whether load-bearing elements are actually present. Often, the brackets are anchored only in drywall, which can quickly become a safety risk.
Furthermore, I wonder if the screws supplied by IKEA are really strong enough for all types of walls. Has anyone had experience with specific alternatives from hardware stores that hold better—especially if the shelves are going to carry heavy books or decorations?
One more point: some people complain about Hemnes shelves tipping over because they are only fixed at the bottom. Would it not make sense to secure the shelves additionally with furniture anchors or tension cables to provide extra safety? This seems to be an underestimated issue.
I can fully understand that installing and securing furniture is a real concern, especially with children or pets around. I had a similar experience with the Hemnes shelves. I also used safety straps from the hardware store that you screw into the wall at the top and attach to the shelf. That provides a really good sense of security.
A question for Attispau: What type of wall do you have? In my case, it was drywall, and I relied on hollow wall anchors. That really stabilizes the setup. I know it’s quite a bit of effort, but it’s definitely worth it, especially for heavy shelves.
And don’t worry, if you work carefully and use the right anchors, it’s actually pretty straightforward. I had doubts too, but in the end, the shelves were stable and secure against tipping.
