ᐅ How can I securely fasten Ikea BESTA units to different types of walls?
Created on: 5 Mar 2019 08:42
kobianca
kobianca
5 Mar 2019 08:42
I am planning to securely and firmly mount my Ikea Besta system to the wall of my apartment. However, I have different wall types: some are solid brick walls, others are drywall panels on substructures, and some are concrete. My question is: which fastening methods and types of wall plugs are best suited for safely and securely fixing the Ikea Besta system to these different wall types? It is especially important to me that the furniture remains load-bearing, that no damage occurs to the walls, and that the mounting brackets from Ikea are used optimally. I look forward to practical advice that includes recommendations for materials, appropriate installation instructions, and any necessary warnings.
U
usron
5 Mar 2019 09:37
Wow, great and very detailed question you asked! The BESTA system is really versatile, but you’re right that wall mounting is essential for stability and safety! 😀 From my own experience: For brick walls, hammer-in anchors with nylon sleeves work well, ideally 8 mm (about 5/16 inch), to safely support both the weight and everyday stress from furniture. For drywall (also called plasterboard or gypsum board), it’s interesting – I use cavity anchors or metal anchors! These usually hold much better than simple toggle bolts. For concrete, hammer-in anchors or injection mortar provide maximum security! Don’t forget to install the supplied wall brackets from Ikea correctly – they offer excellent support! Don’t get discouraged, with the right anchors the BESTA will be rock solid! Good luck with the installation!
blagla
5 Mar 2019 11:03
I would like to add to the discussion, as the material composition of the walls is indeed crucial for choosing the right fasteners. For brick or solid masonry walls, I recommend classic nylon expansion anchors with a diameter of 8-10 mm (0.3-0.4 inches), combined with appropriate screws. It is important to use a suitable drill bit (masonry bit) before drilling and to clean the holes thoroughly to ensure durability. Drywall (plasterboard) is a hollow wall that cannot support normal anchors—metal hollow wall anchors (e.g., toggle bolts) or special spring hooks provide a much better load distribution in the cavity. These should be rated for at least 15-20 kg (33-44 lbs) load-bearing capacity, as the BESTA quickly becomes heavy when filled. For concrete walls, hammer anchors work well; alternatively, injection mortar can be used, but only if you are familiar with the technique, as it is very durable but also more complex during installation.
nera59
5 Mar 2019 14:47
Here is a step-by-step guide for the most common wall types to ensure that the BESTA furniture stays securely mounted for a long time:
- Brick wall:
1. Choose a drill bit with the correct masonry bit (diameter matching the size of the anchor, usually 8 mm (0.3 inches))
2. Blow out the drill hole thoroughly to remove dust
3. Insert the nylon expansion anchor deeply
4. Screw in the mounts with screws appropriate for the anchor
- Drywall:
1. Drill a hole with a drill bit glued together to the recommended diameter for cavity anchors
2. Insert the cavity anchor (toggle bolt or metal anchor)
3. Secure the anchor with a twisting motion and gentle pressure
4. Fasten the screws
Important: Pay close attention to load limits with drywall, and for heavy BESTA combinations, always distribute the weight over multiple mounting points!
- Concrete wall:
1. Use a hammer drill with the appropriate masonry bit
2. Drill deep enough, then remove the concrete dust thoroughly
3. Install hammer anchors or use chemical adhesive anchors
4. Secure the screws
Common mistakes often include dirty drill holes, incorrectly installed anchors, or overestimating drywall load capacity. If desired, I can also compile an overview of the best anchor types for each wall type.
SETHBLA
6 Mar 2019 07:22
For bricks and concrete: use hammer anchors or nylon expansion anchors with a diameter of 8 mm (5/16 inch). For drywall: use metal anchors, not standard plastic anchors. Always align wall brackets from Ikea correctly. This ensures a secure hold.
LENNAU
6 Mar 2019 09:15
nera59 schrieb:
I would like to provide a brief step-by-step guide for the most common wall types to ensure that the BESTA furniture hangs securely and lasts a long time:
Thank you very much for this detailed guide! I would like to add that for drywall (plasterboard) walls, installing a special reinforcement board behind the panel is ideal if the furniture is going to bear a lot of weight. Otherwise, standard cavity anchors can sometimes become overloaded, leading to material failure. Additionally, I recommend checking the wall before drilling with an appropriate detector—for electrical wiring, pipes, or water lines—especially in older buildings. This helps avoid unpleasant surprises and damage. As a general rule: it is better to use multiple anchor points rather than too few, to distribute the load as evenly as possible.
