ᐅ How can I secure Ikea Platsa furniture to prevent tipping over?
Created on: 12 Dec 2019 18:37
Pitiso
Pitiso
12 Dec 2019 18:37
I recently assembled several Ikea Platsa furniture pieces at home, which are very practical and modular. However, I’m concerned about their stability, especially regarding tipping over. Since the units are quite tall and narrow, I want to ensure they won’t tip over during normal use, as well as during minor impacts or when children are nearby.
So my question to the community is: How can I effectively secure Ikea Platsa furniture against tipping? Are there specific fixing solutions, screws, or accessories you would recommend? Should the furniture be attached directly to the wall, and if so, how can this be done without causing too much damage to the wall? What about rental apartments where wall attachments might be limited?
I’m also interested in any experiences or tips regarding assembly, such as how to align the furniture properly or whether adding extra weight layers can help increase stability. I appreciate any advice, as safety and stability are very important to me, especially in everyday life with children or pets.
Best regards!
Garth49
12 Dec 2019 19:24
Hey Pitiso!
Great that you’re thinking about the safety of your Platsa furniture – that’s really important, especially with tall cabinets! 😊
In my experience, there’s nothing better than the original wall fasteners provided by Ikea. They are specially designed to securely fix the furniture to the wall and effectively prevent tipping over! 👍
I’ve attached all my Platsa units to the wall using these metal brackets. You just need the appropriate wall plugs for your specific wall type (drywall, concrete, or brick) and, of course, a good cordless drill. If this is difficult in a rental apartment, at least make sure the furniture pieces are screwed together firmly so they don’t wobble.
One extra tip: some people also use non-slip mats or felt pads under the bases, which greatly improves stability on smooth floors.
Don’t get discouraged, it’s not as difficult as it sounds! You’ve got this! 🔧😉
mesila
13 Dec 2019 07:52
Hello Pitiso,
I would like to provide a structured response because safety with furniture, especially Ikea Platsa, is really important.
First, the basic principle: the greatest safety is provided by wall fastenings. Ikea usually includes screws and brackets with Platsa, which are anchored to the wall using suitable anchors. If your wall is made of drywall, you should definitely use special cavity anchors that securely distribute the weight.
Here is the recommended procedure:
- Check your wall type and obtain appropriate anchors.
- Attach the metal brackets to the designated spots on the furniture.
- Then fasten the furniture to the wall; the screws should be tight, but be careful not to overload the wall.
- Avoid placing weight only on the side of the fastening point.
If wall fastenings are not possible due to rental regulations, you can consider the following alternatives:
- Screw the furniture modules together so they form a solid unit.
- Add weights at the lower section, such as books or boxes, to lower the center of gravity.
- Use anti-slip pads under the feet for better grip.
Regarding wall damage: if you need to drill, you can easily fill and repaint the holes after moving out. This is usually acceptable to landlords as long as there is no permanent damage.
In summary: wall fastenings and proper anchors are the safest option; otherwise, keep the furniture firmly connected and lower the center of gravity. I hope these tips help you!
lis64
13 Dec 2019 12:03
mesila schrieb:
- Check the type of your wall and get appropriate anchors.
- Attach the metal brackets at the specified points on the furniture.
- Then secure the furniture to the wall; the screws should be tight, but be careful not to overload the wall.
That is exactly right. Without the correct anchors, the wall mount will not hold.
I also recommend aligning the furniture before attaching it, making sure it is perfectly straight and measured. After mounting, it’s better to double-check everything.
Imagine the furniture is crooked – any impact could then increase the risk of tipping over.
