ᐅ How can I reinforce Ikea Pax shelves for greater stability?
Created on: 6 Sep 2020 19:37
aureliankl
Good evening everyone!
I recently purchased an IKEA Pax wardrobe and am in the process of setting it up. However, the shelves inside don’t feel very stable—they seem to bend under the weight of books and other items, which is obviously not ideal. My specific question is: How can I secure the IKEA Pax shelves more firmly so they can support heavier loads without sagging or becoming loose?
I have already used the original IKEA shelves along with the provided pins and brackets, but that is not sufficient for my needs. Are there any reinforcements, alternative installation methods, or replacement materials you would recommend? I would appreciate concrete tips, preferably with explanations as to why the suggested method is better than the standard fixing. Thanks in advance!
aureliankl
7 Sep 2020 18:29
sarlo schrieb:
If you want, you can describe your current usage in more detail (e.g., distance between supports, weight per shelf), so more targeted advice can be given.
Sure! The shelves are about 80 cm (31.5 inches) wide. I mostly use them for books, some of which weigh several kilograms (pounds). The supports are the simple, original plastic pins, set about 15 cm (6 inches) apart along the sides. There is no additional support in the middle.
I was thinking of screwing metal brackets underneath the shelf myself but I’m unsure if that would affect the appearance or stability.
Could someone advise me on which steel brackets (dimensions / load capacity) would be appropriate and how to install them best without damaging the existing holes?
kibutar
8 Sep 2020 07:11
Hello aureliankl,
your addition now allows for a much more targeted recommendation.
Regarding your 80cm (31.5 inches) wide particleboard shelf with plastic brackets: the typical load capacity for such shelves is around 15-20 kg (33-44 lbs) evenly distributed, with a significant decrease in load-bearing capacity in the middle. This is why the board bends.
Procedure for a durable and stable solution:
1. Use strong steel brackets:
- Choose brackets made of galvanized steel, with about 30-40 mm (1.2-1.6 inches) leg length and at least 3 mm (0.12 inches) material thickness.
- The brackets can be screwed to the underside of the board. This greatly increases bending resistance.
2. Add a central support:
- Especially for lengths of 80 cm (31.5 inches) or more, a central support or additional rail is essential.
- You can attach a sturdy wood or metal strip to the back wall and rest the shelf on it there.
3. Drilling and installation:
- Do not screw the brackets into the shelf hole surfaces but next to them, to avoid damaging holes.
- Always pre-drill holes (approx. 2-3 mm or 0.08-0.12 inches larger than the screw diameter) before screwing to prevent splitting the material.
4. Alternative reinforcement:
- Gluing a thin laminated wood strip (at least 20 mm (0.8 inches) thick) lengthwise under the shelf is an elegant and strong method to increase load capacity.
From a technical point of view, I recommend combining steps 1 and 2 since brackets alone can loosen over time under continuous load.
One more note: if aesthetics are important, you can also have shelves made of multiplex plywood or solid wood cut to size and mounted with invisible supports. This is more stable in the long term and looks higher quality.
If you like, I can also prepare plans or dimensions for such reinforcements.
