ᐅ How can I reinforce Ikea Pax shelves for greater stability?
Created on: 6 Sep 2020 19:37
aurelianklA
aureliankl6 Sep 2020 19:37Good evening everyone!
I recently purchased an IKEA Pax wardrobe and am in the process of setting it up. However, the shelves inside don’t feel very stable—they seem to bend under the weight of books and other items, which is obviously not ideal. My specific question is: How can I secure the IKEA Pax shelves more firmly so they can support heavier loads without sagging or becoming loose?
I have already used the original IKEA shelves along with the provided pins and brackets, but that is not sufficient for my needs. Are there any reinforcements, alternative installation methods, or replacement materials you would recommend? I would appreciate concrete tips, preferably with explanations as to why the suggested method is better than the standard fixing. Thanks in advance!
Hello aureliankl,
your question about reinforcing the IKEA Pax shelves is very well put. I’d like to offer you a brief guide that can help make the shelves much more load-bearing:
- Reinforce the shelves themselves: The original Pax shelves are usually made of particleboard, which tends to bend under load. You can either replace them with thicker boards or strengthen the existing ones by attaching a thin metal or wooden strip (laminated wood strip or metal bracket) underneath in the middle to increase bending resistance.
- Use additional supports: IKEA offers extra metal supports (often for extensions) that can be installed as additional support points. Alternatively, you can attach metal brackets under the shelves yourself to better distribute the load.
- Replace the shelf pins: Instead of the thin plastic or metal pins that simply slot into the holes, you can use sturdy metal brackets or, ideally, dowels with screws if the cabinet construction allows it.
- Glue shelves together: When using multiple shelves, you can connect them with spacers so they stabilize each other.
- Attach shelves to the back panel: If the back panel is sturdy enough, you can also screw the shelves to it, which limits horizontal deformation.
Be careful not to damage the original drilling holes with any modifications, as this could weaken the cabinet frame.
I hope this gives you a good starting point. If you like, I can go into more detail on any of these points.
giabau schrieb:
The original Pax shelves are usually made of particleboard, which tends to sag under load.This is an important point. From my experience, using reinforced side supports for the shelves helps. These are available as metal brackets that can be screwed in and are much more stable than the typical plastic pins.
Additionally: if you have shelves longer than 60cm (24 inches), an extra center support mounted from the back panel can greatly improve stability.
The most important thing is to strengthen the shelf support points so that the boards are supported not only at the sides but also in the middle.
Hello aureliankl,
I’m generally a fan of stabilizing the foundation first before planning major renovations. Often, floor sagging is related to how heavy the entire construction is and how the loads are distributed on the individual levels.
Two basic tips:
- Position heavy items as close as possible to the side walls, not in the middle of the shelves. This reduces the load on the floor.
- If needed, use additional support strips between the shelf and the brackets. For example, thin wooden slats along the edge under the shelves can increase the bearing surface.
If you want, you can describe your current setup in more detail (e.g., distance between the brackets, weight per shelf) so more specific advice can be offered.
Don’t worry, there is a suitable solution for every problem here.
Two basic tips:
The load capacity of IKEA Pax shelves largely depends on the material and construction. The standard shelves are designed for moderate loads.
In particular, I recommend:
- Replacing the original shelves with MDF or plywood panels at least 18 mm (0.7 inches) thick to ensure greater rigidity.
- Adding metal brackets as supports at the bearing points.
- Using center supports if the shelves are longer than 80 cm (31.5 inches).
These measures make technical sense because chipboard quickly sags under heavy loads, while solid panels and metal fittings increase the load-bearing capacity.
Proper installation is also crucial: the brackets must be securely fastened, ideally with suitable screws in pre-drilled holes.
