ᐅ How can I secure BILLY shelves so they don’t fall out?
Created on: 19 Jan 2022 19:07
fareni
fareni
19 Jan 2022 19:07
Hello everyone, I have a concern regarding my Billy shelves. The shelves keep falling out or coming loose, even though I am using the original shelf supports. The unit is stable and properly secured to the wall, but the shelves don’t fit tightly enough to hold the weight of the books permanently without shifting or even falling out.
I’m wondering if there are any special tricks, additional fastening options, or improved shelf supports that can securely fix the shelves without compromising the appearance or functionality, or becoming too complicated.
Maybe someone has experience with a particularly durable or reliable method to secure BILLY shelves so they don’t fall out? I’m looking forward to any tips, including technical terms or practical solutions, that could help me solve this problem clearly and efficiently.
AUSTINREN
19 Jan 2022 19:22
Basically, the original shelf supports of BILLY are designed to hold the shelves securely when properly installed. However, if shelves fall out, it can be due to the following reasons:
1. Unevenness in the shelf or the shelf unit itself (warping, uneven support surfaces)
2. Worn or bent shelf supports
3. Overloading or uneven weight distribution (e.g., shifted center of gravity)
As a reliable method to secure the shelves, I recommend using screw-in shelf pins (also called dowel pins) instead of simple resting pads. These can be fixed to the side panel with small screws, providing firmer support for the shelf.
Alternatively, some users apply small corner brackets or self-adhesive foam strips at the support points to prevent slipping. It is important that any fixings do not damage the shelf’s structural integrity or the back panel, to maintain overall stability.
GU-LAU60
19 Jan 2022 19:32
I simply screwed a few small angle brackets under the shelves of my BILLY bookcases. This way, they hold reliably even with heavier loads. No major modifications, just two screws per bracket and that's it.
kemads46
19 Jan 2022 21:05
I will explain step by step how to secure BILLY shelves so they do not fall out:
1. First, check if the original shelf supports are still undamaged and straight. If they are bent, replace them.
2. Use screw-in shelf supports (also called shelf pins). These usually have a small screw that fixes the support to the side panel, significantly improving stability.
3. When placing the shelves: make sure the shelf is clean and rests flat on the supports. Unevenness can cause the shelf to wobble.
4. Optional: for extra security, you can attach small brackets underneath the shelves on the inside. Screw these to the side panel to prevent the shelf from falling out. Make sure the screws are short enough so they do not go through the shelf.
5. Avoid overloading the shelves and try to distribute heavy loads evenly.
Summary: The best solution is often a combination of screw-in supports and small brackets. This keeps the shelves securely in place, is reversible, and relatively easy to implement. The appearance remains unchanged, and you avoid driving nails directly into the shelf.
KAUDRA62
20 Jan 2022 08:41
Very interesting topic! 🙂
What I have tried myself and can recommend is attaching self-adhesive rubber bumpers to the shelf supports. This reduces slipping and significantly minimizes the risk of shelves falling out. You hardly notice they are there.
If the shelves are not heavily loaded, this solution works perfectly. However, for bookcases with a lot of weight, I would still recommend using screw fasteners or brackets – the safety really depends on the total weight.
Sometimes the shelves are a bit warped, and in those cases, the bumpers help balance the pressure without applying force.
AUSTINREN schrieb:
As a secure method of fixing, I recommend using screw-in shelf pins (also called shelf supports) instead of simple resting pads.
I fully agree; those screw-in pins are often the best compromise between safety and maintaining the original appearance.
FLONE41
20 Jan 2022 14:19
I can definitely understand how frustrating it must be when shelves keep slipping out unnoticed, even though you’ve done everything right. It almost feels like the furniture just doesn’t want to settle down the way you do 🙂
I had the same problem with my BILLY shelf. What ultimately helped me was a combination of slightly adjusting the shelf supports and gently roughening the shelf sides with fine sandpaper. The foam pad between the shelf and the support helped to absorb vibrations and tiny movements that often cause the shelf to slip out.
Don’t be afraid to carefully make small adjustments in several places. You’ll also get to know your shelf better, which I found really reassuring. 🙂
I agree that this is the safest option, especially if you use the shelves heavily. Still, the solution with rubber pads and minimal adjustments has worked great for me so far, without any visible marks or slipping.
