ᐅ How can I safely assemble Malm beds despite limited space?
Created on: 2 Aug 2021 08:17
Jukubau
Jukubau
2 Aug 2021 08:17
Hello everyone, I would like to ask a more specific question about IKEA Malm beds, which might help me and others with limited bedroom space. How can Malm beds be assembled safely despite very restricted space? Especially in small rooms where there is hardly any free space around the bed, I wonder how to carry out the assembly so that the whole structure is stable and doesn’t cause problems like wobbling or weak points afterward. I am also interested to know if there are special tips or additions to secure the bed to the wall or floor when the space is so tight that you can’t simply assemble the bed freely and move it around. So far, I only have the instruction manual, which is quite general and hardly addresses such tight-space situations. Perhaps someone here has experience or advice on how to do this as safely as possible without damaging the bed or risking instability later on. Thank you in advance!
lorena
2 Aug 2021 09:48
Hello Jukubau, your topic is really important because the secure assembly of furniture in tight spaces is often underestimated. First, I recommend carefully measuring the room before assembly and clearly defining where the bed should be placed. In the case of the Malm bed, the frame is basically designed to be placed relatively easily against walls – but this is exactly where potential pitfalls lie.
Regarding assembly: Since the Malm bed frame consists of several parts, I suggest first assembling the side panels and cross slats separately on the floor, if the space allows. If not, you can also assemble the parts step by step – first build the lower frame structure and then attach the side panels. It is very important to ensure that the screws and dowels are properly and tightly fastened – often they are only hand-tightened initially and should be retightened afterwards.
Jukubau schrieb:
ob es spezielle Kniffe oder Ergänzungen gibt, um das Bett an der Wand oder am Boden zu sichern
This is exactly where I would recommend additionally securing the bed to the wall with brackets. You can use special furniture brackets that greatly increase stability, especially considering that the Malm bed from IKEA is generally not firmly attached to the wall. However, it must be noted that the wall material must be suitable for fixing (e.g., masonry). In very small rooms, you can also place rubber pads under the feet of the bed to prevent slipping, which is particularly important on smooth floors.
If possible, test the overall assembly occasionally for stability, especially after a few days. Retightening the screws is very important for this kind of furniture, especially when subjected to frequent loads and movements.
Finally, it would be interesting to know how much clearance you actually have around the bed and whether the flooring affects the stability. What does your room look like exactly?
BAPAU
2 Aug 2021 10:35
I would advise you not to fully tighten the parts immediately during assembly. First, loosely assemble everything, then check if everything fits properly, and only tighten everything firmly at the end. Use additional angle brackets inside the frame section for reinforcement. If the space is very tight, it helps to assemble the bed without the slatted frame and insert the slatted frame only after the assembly is complete.
Deandre
3 Aug 2021 07:22
Hello Jukubau, I am familiar with your concern about securely assembling Malm beds in tight spaces, as I also live in a small apartment. To make the process easier, I recommend the following approach:
First, be sure to check all screws and components for completeness just before assembly. Especially in confined areas, it is frustrating to have to search for a part in the middle of the process.
lorena schrieb:
I recommend additionally securing the bed to the wall using brackets
I can only agree with that – such brackets provide significant support, provided the wall is load-bearing. If you live in a rental with drywall (plasterboard) walls, be sure to use appropriate anchors; otherwise, there is a risk of the wall breaking.
bapau schrieb:
Use additional angle rails on the inner frame section for reinforcement
That is also a helpful addition. If the bed is stable enough, it reduces long-term wobbling.
Regarding assembly in tight spaces: when the bed is very close to other furniture, it is advisable to work with a helper who holds the parts while you screw them together to prevent shifting. If this is not possible, you can also use special assembly clamps designed to hold parts in place.
Finally, if your room is very small, consider whether the bed’s dimensions really fit. Sometimes smaller bed frame versions or beds with lower storage boxes are an option if space allows. I hope this helps! If you have more precise measurements, we can look at them together.
