ᐅ How can I retrofit Ikea Besta doors with soft-close mechanisms?
Created on: 15 Dec 2020 10:18
babett
Hello everyone, I am planning to equip my Ikea Besta doors with an automatic closing mechanism. Unfortunately, Ikea does not offer this feature as a standard option. My question is: How can I retrofit Ikea Besta doors with automatic closing mechanisms?
I am not just looking for product recommendations but primarily for instructions or guidance on installation, explaining the mechanical or possibly electrical components needed to achieve a smooth, automatic door closing.
It is also important to me to know what special considerations there are during installation, for example when integrating dampers, spring mechanisms, or magnetic switches. Has anyone had experience with retrofit solutions that match the Besta visually and functionally without damaging the door or frame?
I look forward to your tips and experiences!
babett
17 Dec 2020 08:52
RETRAVIS schrieb:
- Most soft-close systems require a minimum gap between the door and the cabinet of about 2-3 mm (0.08-0.12 inches).
- If the gap is too small, the damper won’t work properly or may damage the door over time.
That’s important to know, thanks. My doors are currently quite tight against the cabinet. Would it be necessary to increase the gap on site using shims or other means? Is this something that can be done without much effort, or would the design need to be altered?
Also, I was considering whether, in addition to the soft-close dampers, it might be worth installing some kind of self-closing mechanism that fully closes the doors automatically, so they never remain open. Is there a practical way to combine these so the door closes automatically and is then gently caught by the damper?
I appreciate any insights.
Parbo
17 Dec 2020 10:43
babett schrieb:
My doors are currently quite close to the cabinet frame. Would it be necessary to increase the gap using shims or other methods at the installation site?
Yes, if the doors are too close to the frame, the function of the soft-close dampers can be affected. A simple solution is to place spacers under the hinges or use thin washers on the mounting screws to slightly adjust the door position without altering the furniture construction.
babett schrieb:
Is there a practical combination that allows the door to close automatically and then be softly damped?
Such systems do exist. Combination hinges or sets that include a return spring for automatic closing combined with a damper to softly catch the door. However, implementing this can be somewhat complex, as it often requires replacing existing hinges and precise door alignment.
I recommend the following approach:
- Check your current hinges for compatibility with soft-close spring combinations.
- If possible, switch to a soft-close spring hinge type.
- Carefully adjust all doors after installation to prevent misalignment.
Although this involves some effort, it ensures automatic closing with a damped final phase.
Friedrich
17 Dec 2020 14:06
Hello babett,
I completely understand that you want a convenient solution that closes quietly and automatically. It can be a bit tricky at first, but with patience, it usually works out well.
I was particularly interested in your desire to maintain the appearance and originality. For that, it’s best to choose retrofit options of the same quality level that can be integrated discreetly.
Don’t worry too much about possible modifications. If something doesn’t work out, it’s not the end of the world. Many people here in the forum have successfully completed similar projects. Please keep us updated, especially if you have any questions or if anything is unclear. Topics like these always benefit from sharing experiences.
Best of luck with your project!
