ᐅ How do I repair scratches on IKEA HEMNES wood surfaces?
Created on: 13 Feb 2021 08:43
SONPO65
SONPO65
13 Feb 2021 08:43
I have an issue with some noticeable scratches on the wood surfaces of my IKEA Hemnes furniture. Since these are mostly veneered surfaces with a clear protective coating, I’m unsure how to proceed without causing further damage or uneven color variations.
Specifically, the scratches are light to moderate surface scratches on dressers and nightstands, resulting from everyday use. My questions are:
- Which materials or products are best suited for repairing this type of scratch?
- Are there any effective home remedies that can help avoid having to replace the furniture?
- Should the surface be cleaned or sanded first, and how deep is it safe to work on a veneered piece?
- How can uneven coloration or incorrect gloss levels be prevented afterward?
I look forward to helpful suggestions that don’t simply recommend buying new furniture but offer practical repair solutions. Thank you in advance!
mifra
13 Feb 2021 09:17
IKEA HEMNES furniture typically features veneered MDF or solid wood surfaces with a thin clear lacquer or cellulose foil layer. For scratches on these surfaces, I recommend the following procedure:
- First, clean the surface with a mild, lint-free cloth and some water or a specialized wood cleaner.
- For light scratches, gently buff a brown wax paste or treated furniture wax into the surface with a soft cloth to visually minimize the scratches.
- For deeper scratches, use an appropriate wood repair marker (matching the wood color), apply carefully, and allow it to dry thoroughly.
- If needed, carefully blend the transitions with a fine abrasive pad (around 400-600 grit), but only if the lacquer is damaged – sanding the entire surface is not advisable.
Important: Never sand aggressively, as the veneered wood is very thin and you risk damaging the protective layer. Also, avoid using highly oily or water-soluble substances, as they may damage the surface. The gloss level can be adjusted with a water-based furniture polish.
These methods can restore most scratches without the need for repairs or replacement.
rebufar
13 Feb 2021 11:05
To be honest, I think the constant recommendation of furniture polish or wax paste is often overrated. Especially with HEMNES, the veneer layer is so thin that any half-hearted treatment tends to make the surface worse. In such cases, it makes much more sense to get out the soldering iron and color-matched repair kits right away.
I can hardly imagine that a wax stick would have a lasting effect on a genuine scratch. It always leaves that strange shiny spot that stands out even more. If you want a proper long-term solution, you need to clean more thoroughly, sand, and repaint — which also saves money in the long run.
But well, to each their own.
Laukau5
13 Feb 2021 13:23
To deepen the discussion a bit: The HEMNES surfaces are usually sealed with a thin clear varnish that provides some protection against mechanical impacts but does not allow for thorough repairs.
For scratch repairs, I recommend the following procedure:
- Cleaning: Remove dirt and grease using a mild cleaning agent, such as a low-concentration isopropanol solution, to avoid leaving residues.
- Assess the scratch depth: Are these just superficial micro-scratches, or have the scratches penetrated through the varnish into the wood?
- For micro-scratches: Lightly roughen the area with fine sandpaper (grit 1200 or higher), then apply a suitable clear varnish matching the original (e.g., acrylic water-based varnish) spot-wise.
- For deeper scratches: Use fillers such as wood putty or color-matched wood repair pastes, then sand and apply clear varnish.
- It is important to sand lightly between varnish layers using very fine sandpaper (grit 600–1200) to ensure a smooth surface and adjust the gloss level.
This is the technically cleanest method but requires some tools and patience. For less effort, wax paste can be used as a temporary visual fix to improve the surface appearance in the short term.
SONPO65
14 Feb 2021 07:56
Laukau5 schrieb:
For micro-scratches: Lightly roughen the surface with sandpaper (grit 1200 or higher), then apply a suitable clear coat that matches the original (e.g., water-based acrylic clear coat), applied spotwise.
Thank you for the detailed description; that sounds reasonable. However, I am unsure about which clear coat to use ideally. IKEA does not provide specific recommendations, and I want to avoid the clear coat having a different gloss level than the surrounding area. Are there clear recommendations for types or brands of clear coats that have proven effective and work well with the HEMNES finish?
Also: Should the area be treated with a special primer or adhesion promoter before applying the clear coat to improve durability? Or is thorough sanding and direct application enough?
I would prefer to minimize experimenting since I do not have access to a professional workshop.
mifra
14 Feb 2021 08:37
SONPO65 schrieb:
Are there clear recommendations for types or brands of clear varnish that have proven reliable and work well with the HEMNES finish?
I recommend a clear water-based acrylic varnish with a matte or satin finish. These types of varnishes have proven to be the most suitable in furniture restoration because they have relatively low odor and offer similar surface qualities.
A special primer is not necessarily required on veneered surfaces, provided the clear varnish is applied to a cleaned and lightly sanded surface. It is important to sand very finely (starting at grit 1000) and ensure the surface is dust-free before application.
In my own experience with similar finishes, I have had good results using brands specifically marketed for wood and furniture coatings, without looking for OEM brands, as others are often targeted at synthetic resin or automotive paints.
Patience during drying and applying several thin, even coats will produce a consistent result and prevent unsightly buildup or drips.
