ᐅ How do I repair scratch-resistant IKEA Metod cabinet fronts?
Created on: 22 Nov 2021 14:37
berekla
berekla
22 Nov 2021 14:37
I have kitchen cabinet fronts from the IKEA Metod system, which are advertised as scratch-resistant. Unfortunately, some small scratches have still appeared on the white lacquered surfaces—probably due to daily use and placing objects on them. Now I’m interested in how I can best repair these scratches myself without having to replace the fronts completely.
My goal is to find either a method or a product that restores the surface to be as smooth and inconspicuous as possible, without damaging the matte-white finish or leaving visible repair marks. I have already read about polishing products and special repair kits but am unsure whether these really work on the specific scratch-resistant lacquers used by IKEA Metod or if they might cause more damage.
Does anyone here in the forum have experience or recommendations for an efficient and material-friendly repair of such scratch-resistant kitchen fronts? If so, what are the recommended steps, which products are suitable, and how can I avoid causing further damage while trying to fix the scratches?
Thanks in advance for your help!
pikin
22 Nov 2021 16:02
Hello berekla,
IKEA’s Metod fronts often have a surface made of melamine or a special scratch-resistant coating. While these surfaces are more durable than traditional paints, scratches are not always easy to repair.
First, it is important to carefully assess the damage: Are the scratches very superficial or deeper? Superficial scratches can often be reduced using very fine sandpaper (grit 2000 or higher) followed by polishing with a plastic or furniture polish product. It is important to apply very gentle pressure and use only a small amount of product to avoid further damaging the surface.
For deeper scratches, it is advisable to be cautious with repair kits, as many paint pens or repair sets designed for wood or standard paints do not adhere well or remain visible on scratch-resistant melamine surfaces.
I recommend the following procedure:
- Clean the surface with a mild, grease-free cleaner
- Gently sand the scratches using a fine sanding sponge or wet sandpaper (2000+ grit)
- Polish with a special plastic or furniture care product suitable for painted kitchen fronts
Alternatively, you can ask IKEA directly for a repair kit specifically developed for Metod fronts.
Caution: Never use aggressive abrasives or solvents that could damage the coating.
Regards
Timofa
22 Nov 2021 18:17
Hey berekla,
I know the problem—Metod fronts are really sturdy, but sooner or later you’ll catch some small scratches anyway! 😅 My tip: try using a mixture of toothpaste and a little water—it gently polishes the surface, and the scratches become surprisingly less noticeable. Don’t worry, a bit of courage and careful rubbing with a soft cloth usually does the trick.
pikin schrieb:
For deeper scratches, it’s best to be cautious with repair kits, as many paint pens or repair sets for wood or standard paints don’t adhere well or remain visible on scratch-resistant melamine surfaces.
I think this point is really important! There are tons of repair kits for wood or plastic, but hardly anything really good for the Metod system that actually lasts.
If the scratches are too large, I’d suggest carefully removing the front and asking IKEA for replacement parts—sometimes individual fronts are cheaper than you’d expect.
Good luck with the repair! 🍀
Laukau5
23 Nov 2021 09:48
Good morning everyone,
I would like to add some technical details about the scratch-resistant Metod fronts, as this topic is often misunderstood here.
These fronts usually have a thin, durable film coating (mostly melamine resin) or are coated with a UV-cured lacquer layer. These coatings are mechanically robust but are not traditional paint finishes that can be sanded and repainted.
If you try to treat the surface with too coarse sandpaper, you will remove the protective layer and make the surface even more vulnerable. This means:
- Use only very fine wet sandpaper (grit 2000 or 3000) and apply minimal pressure.
- After sanding, use a special plastic polish that smooths and visually evens out the surface.
- Alternatively, repair felts or pads are suitable, which allow very fine sanding and polishing.
It is also important to thoroughly clean the area beforehand to avoid rubbing dust or dirt into the surface. I would also recommend testing on a small area first.
Question berekla: About how deep are your scratches, and can you see with a magnifying glass whether the lacquer or film surface is damaged in some spots? This is crucial for determining the repair options.
Best regards!
berekla
24 Nov 2021 11:21
Laukau5 schrieb:
Question berekla: How deep are your scratches approximately, and can you see with a magnifying glass whether the paint or film surface is damaged in some spots?
Thank you for your detailed post! I would describe the scratches mostly as superficial; a magnifying glass shows only small unevenness on most areas, but no missing film or chipped spots. However, there is at least one spot where the surface looks somewhat duller and rougher—maybe a slightly deeper scratch or abrasion.
So far, I have only cleaned the fronts with a damp cloth, without sanding or polishing. At this point, I would be cautious, especially since I don’t want to make any damage worse.
Therefore, I’m inclined to start by using special polishes designed for scratch-resistant surfaces. Are there any specific product recommendations or brands that you know from personal experience?
Also, the idea of cleaning before treatment sounds very sensible. I will clean the surfaces first with a mild dish detergent and a lint-free cloth.
Thanks again for your valuable tips!
