ᐅ How do I repair IKEA Platsa screws or components?
Created on: 11 Aug 2021 17:23
Lenko
Lenko
11 Aug 2021 17:23
Hello everyone, I have an issue with my IKEA Platsa cabinets and hope to get some helpful advice here. Over time, some screws and connectors have loosened or even become partially damaged. The connection fittings on the side panels are particularly affected, sometimes creaking or wobbling when opening the doors. The screws themselves strip, which reduces the stability.
My question is: How can I specifically repair IKEA Platsa screws or components to make the furniture stable and fully functional again? Are there proven techniques, replacement parts, or tools I can use without having to dismantle the entire piece? I would like to know if damaged screws can be tightened again, perhaps using a filler material, or if they need to be completely replaced, and what the recommended approach is for seized or stripped connection fittings.
I appreciate practical tips or experiences with repairing Platsa, thank you in advance!
kulau
11 Aug 2021 18:12
Hello Lenko, your issue with the Platsa screws is quite common since IKEA furniture is often made from wood-based panels that can lose their load-bearing capacity at the screw points after frequent use or repeated assembly and disassembly.
First, you should precisely identify the type of screws and connectors – Platsa typically uses cam lock fittings and barrel nuts. If the screws are stripping, it often helps to repair the screw holes as follows:
- Remove the screw and clean the hole from dust and loose wood fibers.
- Fill the hole with wood filler or alternatively use wooden dowels if the hole has become too large.
- Let the material dry thoroughly (depending on the product, this can take several hours up to overnight).
- Drill a small pilot hole for the screw into the repaired area to ensure the thread can grip again.
- Carefully screw the screw back in without applying too much force to avoid damaging the new material.
If the cam lock fitting is damaged, these can often be reordered from IKEA, or universal connectors are available from specialist retailers. An important tip: for stuck fittings, a spray lubricant is recommended (not WD-40, but a light machine oil works better) along with some patience to loosen them. Be sure to refasten the connection afterward, since the thread might sometimes be damaged by the lubricant.
In summary, here are the key steps:
- Repair screw holes with filler or dowels
- Request replacement parts from IKEA
- Screw carefully, avoid over-tightening
- Treat stuck connectors with special care
Feel free to ask if you need more details about tools or replacement parts!
Tommy38
11 Aug 2021 18:55
kulau schrieb:
If the cam lock fitting is damaged, you can often reorder it from IKEA, otherwise universal connectors are available at specialist retailers.
Exactly. I also recommend referring to the Platsa assembly instructions again, as they usually provide a clear overview of the screw types and their positions. For tightening, it’s best to use a good Phillips or Allen screwdriver, depending on the screw type.
Regarding stripped screws: if the screw is already loose, you can try a small trick—apply a bit of wood glue to the screw shaft, then screw it back into the hole. This will help the screw grip again. However, it’s important that the hole is not too large!
If that doesn’t work, I would really recommend using smaller wooden dowels and drilling the hole anew. This often provides better stability than just filling the hole with filler material.
Additionally, you can check the furniture parts to see if there are specific replacement components for the Platsa system. IKEA customer service usually helps with this.
Lenko
12 Aug 2021 09:38
kulau schrieb:
If the screws spin out (“strip”), it often helps to repair the screw holes
Thanks, kulau, that’s a very helpful tip. You’ve hit the nail on the head—the screws are indeed stripping. You mentioned wood filler and wooden dowels—could you briefly explain the difference? Which material would be better suited for flat-pack furniture made from particleboard?
Tommy38 schrieb:
put a bit of wood glue on the screw shaft, then screw it into the hole
That sounds interesting too, but I wonder if wood glue might dry too hard inside the hole, making it difficult to remove the screw later if needed. How long should you wait before the screw can be put under load again?
Question for everyone: Has anyone ordered replacement parts (e.g., cam lock connectors) directly from IKEA? Were they delivered quickly? Or is it better to go to a specialized local retailer?
Looking forward to your experiences.
SUDAN
12 Aug 2021 11:21
Lenko, we can gladly address your questions in a structured way:
1. Difference between wood repair filler and wooden dowels:
- Wood repair filler is a ready-to-use filling material. You apply it into the stripped screw hole, smooth it out, and let it dry. After drying, the hole is filled and ready for a new pilot hole. It is especially suitable if the hole is already visibly damaged. The advantage: no drilling needed.
- Wooden dowels are wooden pins that are glued precisely into the hole. Once the dowel has dried, you drill a new hole directly into the dowel and screw in again there. This is often more stable than filler because it replaces the material with real wood. For chipboard panels however:
- Filler is easier to work with and compensates for unevenness well.
- Dowels offer better hold but are technically more demanding, and with lower-quality chipboard the dowel might not grip properly.
2. Wood glue in the screw hole:
You are right, it hardens completely, so the glue should be used sparingly. A drop on the screw can increase the strength of the joint and prevent the screw from turning loose. However, the glue does not act like an adhesive between the furniture part and the screw, but rather as a filler that surrounds the threads.
Waiting time: Ideally at least 4–6 hours, better overnight, before putting any load on the screw.
3. Spare parts from IKEA:
Many people report fairly quick delivery (usually a few days). Customer service for Platsa is generally well equipped since the furniture is still in the current range.
There is no problem with visiting a specialty store depending on urgency, but not all connecting hardware is standardized.
Summary:
- Use wood glue sparingly for minor repairs
- For larger damage, use wood filler or dowels
- Best to order spare parts directly from IKEA
If you like, I can also prepare a detailed step-by-step guide for you.
