ᐅ How do I repair Ikea HEMNES furniture that has warped due to moisture?
Created on: 9 Dec 2016 09:17
Tuncay
I have a rather specific problem with my Ikea Hemnes furniture. Due to moisture, some parts have visibly warped, especially the doors and shelves. The deformations are partly bent and partly slightly swollen, which affects their functionality.
I’m interested in hearing if anyone has experience repairing such damage on HEMNES pieces. Specifically:
- What methods are available to straighten the wood (mostly MDF or solid wood with a lacquer finish)?
- Does sanding followed by oiling or repainting work, or is that counterproductive for moisture damage?
- Are there any special moisture barriers or wood treatments I could use to prevent further warping?
I want to approach this as sustainably and appropriately for the material as possible, so rather than simply replacing parts, I prefer repairing. If you have any tips on tools or products, please share.
I’m looking forward to your feedback and thank you in advance for your help!
PERON
10 Dec 2016 09:10
Tuncay schrieb:
Today I can say that the deformation has slightly reverted, but the furniture piece is not completely straight yet.
Hey, that’s already great progress!
In my experience, you can repeat the process several times, but really only with care. If the MDF gets too wet, it loses strength. So it’s better to do it more often but with less moisture.
Regarding surface treatment: I personally prefer a combination of a sealing spray plus clear varnish. The spray provides extra water-resistant protection, and the varnish keeps the surface nice and smooth.
Don’t get discouraged; small successes add up!
neoren
10 Dec 2016 09:44
On the topic of material fatigue:
Repeated dampening and bending can weaken MDF boards. Therefore, proceed gently and precisely.
Polyurethane varnish is ideal as it creates a durable, waterproof layer. Furniture sprays are often additives, but they do not replace a good varnish.
SINTAR
10 Dec 2016 10:02
I would proceed as follows:
- Repeat drying several times if necessary.
- MDF must not become too wet, otherwise the surface will collapse.
- Polyurethane varnish as surface sealant.
Be careful when bending, the material is brittle.
