ᐅ Which materials are suitable for creating a custom front for IKEA Besta units?
Created on: 27 May 2018 09:12
kerolis
I am planning to build a custom front panel for my IKEA Besta shelving unit and am looking for the best materials suitable for this purpose. It is important to me that the front panel is sturdy, relatively easy to work with, and visually appealing. Additionally, the material should absorb minimal moisture and ideally be easy to paint or coat. Does anyone have experience with suitable materials for front panels? What are the pros and cons of options like MDF, plywood, or HPL panels?
I look forward to your advice!
nedagla schrieb:
Definitely something to consider for a DIY look.Absolutely! Natural wood always creates a cozy and unique atmosphere. However, you should treat it properly to prevent moisture and dirt from penetrating. Oils and waxes are highly recommended and can be easily applied yourself.
Thanks for all the support so far!
What do you think: if I laminate a surface with durable high-pressure laminate (HPL) over MDF, could I get the best of both worlds? Using MDF as a substrate because of its good workability and HPL as a protective layer – would that make sense? Are there any experiences regarding the durability and processing of insulation boards on MDF? How complex is the overall installation?
FABIAN_DEO28 May 2018 13:22kerolis schrieb:
If I bond a surface with durable laminate (HPL) onto MDF, would I be able to get the best of both materials?Basically, yes. This combination is even popular in the furniture industry. MDF as a substrate provides a smooth and easy-to-work surface, while HPL offers a very durable finish. However:
- Bonding HPL to MDF must be done carefully; the adhesive needs to be evenly spread without any air bubbles.
- The edges require special attention, as HPL is often thicker than MDF and can protrude.
- Cutting and milling should be completed before bonding, since HPL is difficult to trim afterwards.
I also recommend finishing the edges with edge banding or edge protectors to improve both durability and appearance. Overall, this is a very sturdy and professional method but requires more preparation work.
Here is a summary:
- MDF is affordable, easy to paint, and simple to work with, but sensitive to moisture
- Plywood is heavier, more durable, and offers an attractive natural look
- HPL provides the highest durability and moisture resistance but is more difficult to process
- Combining MDF as a base board with glued-on HPL can combine the advantages but requires precise work
This is very helpful, thank you! I think I will start with MDF and maybe try a matte finish. Could anyone give tips on which type of paint or sealant is particularly suitable for protecting the surface from moisture over time?
A 2-component polyurethane (2K PU) coating is well suited for a durable and moisture-resistant surface. It is robust, chemical-resistant, and waterproof. However, for DIY enthusiasts, a high-quality acrylic paint with multiple layers and intermediate sanding is often sufficient. It is always important to seal the edges and reverse sides as well.
