ᐅ Is there a simple way to protect Billy shelves from moisture?
Created on: 4 Apr 2019 09:13
Lo-tommaso
Hello everyone, I have an issue with my IKEA Billy shelves: they are located in a room with relatively high humidity, and I’m concerned that the shelves might sustain damage from moisture over time. I’m particularly interested in whether there is a simple way to effectively protect the Billy shelves from moisture without having to completely rebuild or treat them. Ideally, I’m looking for a practical solution that requires relatively little effort and cost but still provides long-term protection. Are there any experiences or proven tips in this forum for protecting Billy shelves from moisture damage?
semuneo
4 Apr 2019 15:27
Lo-tommaso schrieb:
I haven’t attached the shelf to the wall yet.
You can definitely do that; it increases stability and prevents moisture from entering from the back since the shelf will sit closer to the wall.
Another idea I had: a small dehumidifier in the room can provide additional protection if the humidity levels are consistently too high.
Gino38
4 Apr 2019 18:20
In summary, the most practical measures are:
- Replace the back panel made of thin cardboard with MDF or plastic sheets
- Paint edges with water-resistant lacquer
- Use furniture feet to avoid direct contact with the floor
- Attach to the wall for stability and better protection
- Monitor indoor humidity and use a dehumidifier if necessary
This way, the main risk areas are minimized.
Timurki8
5 Apr 2019 09:08
Great to see everyone joining in here! 🙂 Let me try a little joke: If you really love your Billy bookcases, give them a little sunshade—indirectly, that is. A thin curtain in front of the window can absorb half as much moisture ;-)
Jokes aside, I believe a combination of all the mentioned measures will yield the best results. In other words: protective film, paint, and air circulation together work great.
bijo54
5 Apr 2019 10:03
A dehumidifier helps with high humidity. Otherwise, use silicone on cut edges, a waterproof back panel, and furniture feet.
gekira
5 Apr 2019 11:20
I would like to add that for painting, it is best to use products specifically designed for particleboard or MDF, as these provide better adhesion and prevent chipping.
It is also advisable to allow the shelves to dry completely after sealing before placing any objects on them, as moisture can otherwise become trapped within the material.
Teonon
5 Apr 2019 13:07
gekira schrieb:
Do not let it chip off and allow it to dry completely.
This is absolutely crucial! Patience when painting really pays off. Sometimes people underestimate that.
