ᐅ How can I repair paint scratches on IKEA Hemnes furniture?
Created on: 1 Jan 2021 10:07
Tili38
Tili38
1 Jan 2021 10:07
Hello everyone, I have some Hemnes furniture from IKEA, mainly dressers and nightstands, where the finish has worn off in certain areas. I am particularly interested in how to repair these worn spots in a way that visually hides the damage as best as possible while also protecting the furniture surface in the long term. What materials and methods are best suited for repairing, especially with the typical matte, mostly lacquered finishes of Hemnes? Are there proven approaches that are simple to carry out without having to repaint the entire surface? I would appreciate practical tips and step-by-step instructions!
REOHEINRIC
1 Jan 2021 10:23
The repair of paint scratches on Hemnes furniture can be carried out effectively with the following steps:
- First, gently roughen the affected area with fine sandpaper (grit 400-600) to remove any loose paint flakes and create a surface for adhesion.
- Then, carefully clean the area using a slightly damp cloth with a small amount of cleaning agent to remove dust and grease.
- For color touch-up, water-based wood lacquer pens or paint that closely matches the original shade work best. IKEA sometimes offers repair kits, otherwise color mixing is available at hardware stores.
- Apply the lacquer in thin layers and allow each layer to dry thoroughly.
- Finally, lightly polish the surface with a very fine sanding pad or sandpaper (grit 800 or finer) to smooth out transitions.
This method is relatively straightforward and avoids the effort of a complete repaint.
Seanni
1 Jan 2021 11:12
REOHEINRIC schrieb:
For refreshing the color, water-based wood touch-up pens or paints that match the original shade as closely as possible work best.
Absolutely, the key is really to match the color as precisely as possible – otherwise, you often end up noticing the “spot” more than the furniture piece itself.
Some people also simply use touch-up or glaze pens available in decor stores, which makes the process a bit more fun and straightforward. If you approach it casually, the result can quickly look great again!
Also, if you want to do some additional touch-ups: applying a very light coat of wax never hurts, it makes the surface more durable and feels great to the touch – almost like new. 😉
Lorukeo
2 Jan 2021 09:46
After adding the previously mentioned points, I would like to add the following:
- Hemnes furniture is usually made of painted pine wood, so it is important to use solvent-free or at least low-emission products to avoid further damaging the paint layer.
- If the abrasion is very deep and the raw wood is visible, it often helps to fill the area with wood filler (white or color-matched). After it dries, apply paint over it.
- For color matching, it is recommended to bring a small piece of the furniture or a photo with a color comparison to a specialist retailer to achieve the closest possible shade.
These details significantly improve the durability and appearance of the repair.
Jodyro
2 Jan 2021 12:14
The best approach:
- Sand
- Clean
- Buy a touch-up paint pen in the matching color
- Apply the paint
- Let it dry
This is usually sufficient.
refinar
3 Jan 2021 08:58
Here is a simple step-by-step guide that has proven effective:
1. Surface preparation:
Lightly sand with 400-grit sandpaper to prepare the surface.
2. Cleaning:
Remove dust and residues with a lint-free, damp cloth.
3. Finding the right color:
Mix color samples using different paint markers or small paint cans on a piece of cardboard. Since Hemnes usually uses matte finishes, pay attention to more matte variants.
4. Painting:
Apply thin layers with a brush or marker. Allow sufficient drying time between coats (at least 2 hours).
5. Smoothing:
After drying, carefully smooth with 800-grit or finer sandpaper, avoiding creating edges.
6. Sealing:
Optionally, apply a thin layer of wax or a matte clear coat to protect the surface.
Common mistakes include applying paint layers that are too thick or choosing a color that doesn’t match the original. It’s better to apply multiple thin layers and measure carefully.
