ᐅ How can I repair broken handles on Ikea BESTA units?
Created on: 5 Dec 2022 10:17
bureo7
bureo7
5 Dec 2022 10:17
I have an issue with some broken handles on my Ikea Besta system. The handles are mounted directly on the front of the doors, and unfortunately, the plastic mounts have broken on several of them, causing the handles to become loose or fall off completely.
I’m mainly interested in methods or materials to repair these handles without having to replace them entirely.
Does anyone know of reliable techniques, whether adhesives, repair kits, or a specific approach that is stable and long-lasting? It would also be helpful to know if the handles can be secured from the inside, if you have access to the broken area.
Thanks in advance for your tips and experiences!
Jeanbar
5 Dec 2022 11:04
Hello bureo7,
Regarding broken handles on Ikea BESTA units, I can share some practical tips that have proven effective. First, it’s important to examine the break closely:
- Is the break on the plastic holder, or is the handle itself damaged?
- Is the break clean, or are there cracks that could complicate the repair?
If the handles are still intact and only the plastic holder has broken, a high-quality two-component plastic adhesive (epoxy resin) is often the best choice. The surfaces to be bonded should be dry and clean; then apply the adhesive thoroughly to both the handle and the broken part and secure them firmly. A strong bond is only ensured after full curing, usually 12–24 hours.
Some users also reinforce from the inside if the construction allows it: this could be a small metal plate or a spacer sleeve fixed with screws to distribute mechanical stress.
If the break is too large or several handles are affected and replacement parts are no longer available, third-party replacement handles that fit similarly can be used. The downside is that drilling holes may need to be adjusted.
Feel free to describe the break in more detail, and I can provide more specific advice.
kieran
5 Dec 2022 12:21
In addition to Jeanbar’s comments, I would like to point out that the choice of adhesive is crucial for durability.
- Epoxy resin is well suited for bonding plastic and metal parts, as it offers high shear and tensile strength.
- Superglue (cyanoacrylate) can provide quick fixes for small cracks but is often brittle and may break again under stress.
It is recommended to thoroughly clean the area to be glued beforehand, removing any dust, grease, or other contaminants, preferably with isopropanol.
During assembly, you should also check whether the screw holes are still intact. Sometimes the thread in the door panel breaks off, which then requires repair using larger screws or a washer. In rare cases, a special repair kit for furniture threads (e.g., metal inserts) can help.
If you can provide exact measurements of the handles or photos of the break, it may also be possible to assess whether internal reinforcement is an option.
Genevieve
6 Dec 2022 08:37
I wonder if this adhesive really always performs with long-lasting durability, since the stress on the handles is usually quite cyclical – constantly pulling and pushing.
Does anyone have long-term experience with this, or advice on how to additionally relieve the adhesive joint mechanically?
Perhaps a small metal bracket or ring could be installed between the handle and the door to protect the adhesive joint? I find that adhesive alone usually doesn’t hold up well in everyday use, especially with plastic pulls.
Also, I’m interested to know if Ikea possibly offers official replacement parts for the handle mounting. Otherwise, a complete replacement of the handles might be better, even if it seems more complicated.
Laukau5
6 Dec 2022 14:52
I would like to provide a more detailed explanation regarding the repair of broken handles on the Ikea BESTA system, as I believe this topic is often addressed too quickly with simple glue tips.
Detailed procedure:
- First, carefully examine the break point. Many BESTA handles connect plastic holders with metal cylinders. If only the plastic has broken, good results can often be achieved by replacing the plastic part or by combining adhesive bonding with mechanical reinforcement.
- For adhesion: epoxy resin is preferable since it can withstand mechanical stress well after curing. It is important to have a precise fit to avoid gaps where the glue might fail.
- If possible, I recommend installing a small reinforcement plate on the inside of the door. This can be secured either with longer screws or bonded with a second adhesive point.
- Alternatively, you can replace the original fastening system with a version using screws and metal sleeves. Although this increases the effort, it results in significantly more stable handles.
- If you can no longer obtain replacement holders, I suggest replacing the handles entirely. Ikea offers some BESTA handle designs that can be swapped out with minimal effort, without needing new drill holes.
As a tip: Ikea sometimes uses modular handles for which replacement parts can be ordered directly. Contacting their customer service can be helpful.
Finally, @bureo7: How heavily do you use your handles? Are they often subjected to significant pulling forces, or do you use them under normal conditions?
Jeanbar
7 Dec 2022 09:10
Genevieve schrieb:
I wonder if this adhesive really holds up over time, since the stress on the handles is usually quite cyclical.
That's a very good point. In fact, I have noticed that with frequent use—such as in a household with children or heavy traffic—the glued joints can eventually weaken.
Therefore, I always use a combination of adhesive and screws where possible to distribute the tensile load.
That’s a good addition I can also highly recommend. It helps reduce stress on the adhesive bond, which extends its lifespan.
If you can reinforce the handles from the inside, @bureo7, you should definitely try that—I did the same on my BESTA and the stability immediately improved.
Otherwise, the key is to work carefully, roughen the surface well, allow the adhesive to cure thoroughly, and add mechanical fasteners where possible.
