ᐅ How can I remove scratches from Billy cabinet doors and shelves?
Created on: 12 Aug 2019 18:27
Siro8
Siro8
12 Aug 2019 18:27
I have noticed some scratches on the doors and shelves of my Billy bookcase that occurred during normal use. Since the surface is made of melamine-coated chipboard, I would like to know the best methods to remove or at least visually improve these scratches. I am particularly interested in tips on how to repair the damage so that the surface is affected as little as possible in appearance. Are there any special home remedies, paints, or tools suitable for this type of scratch?
I want to avoid removing or replacing the entire door or shelf, as that would be very time-consuming. I would be very grateful for any helpful, practical advice!
sihau
12 Aug 2019 19:03
Siro8 schrieb:
I am particularly interested in tips on how to repair the damage so that the surface is affected as little as possible visually.
For melamine-coated surfaces like those on Billy shelves, it is recommended to start by cleaning with a mild detergent to remove dirt. Minor scratches can then be treated with color-matched furniture markers. There are special repair kits available for laminate and melamine surfaces that contain wax or synthetic resin fillers.
To apply, first lightly sand the scratch (using very fine sandpaper, e.g., grit 600), then apply and smooth out the repair material. After it dries, the surface can be polished with a soft cloth.
Complete sanding or repainting is generally not recommended for melamine, as the coating does not adhere well and the original gloss cannot be restored. Alternatively, scratches can be fairly well concealed with special furniture creams or color-matched touch-up pens.
V
vinli
13 Aug 2019 07:14
sihau schrieb:
light sanding, apply repair material and smooth
Adding to sihau’s comment: For slightly deeper scratches, it helps to clean the area with isopropyl alcohol before applying repair wax or filler to remove any grease and dust residue.
For color matching, markers designed specifically for wood or laminate surfaces work well. Application should follow the instructions—often several layers are needed to achieve good coverage.
It is important not to use harsh cleaners on the surface afterward, as this can damage the repair.
pakokla
13 Aug 2019 09:52
You can fix small scratches with beeswax or furniture wax. For deeper ones, a repair kit from the hardware store helps. For very deep cracks, the only effective solution is replacement.
Roninkla
14 Aug 2019 11:37
pakokla schrieb:
No solution is effective for very deep cracks except replacement.
That is correct. Surfaces coated with melamine resin are relatively durable, but very deep scratches are hardly repairable invisibly. In such cases, replacement is usually more cost-effective.
However, if the scratches are only superficial, applying color-matched repair wax or specialized pastes is generally the best option. Avoid excessive sanding, as it can cause further damage to the surface.
U
usbla
15 Aug 2019 16:03
I would recommend carrying out the repair with a kit specifically designed for melamine-coated furniture.
It is important to test the product on an inconspicuous area before application to avoid color mismatches. Using a soft cloth to polish after the repair also significantly improves the result.
Commonly used furniture sticks or waxes are usually based on synthetic wax or plastic fillers, which fill in the scratches but do not fully restore the surface. For long-term durability, it is advisable to use high-quality kits.
