ᐅ How can I remove adhesive residue and old film from Ikea Besta furniture without causing damage?
Created on: 19 Mar 2018 21:43
RENILE
Hello everyone, I removed some old self-adhesive films from my IKEA Besta furniture, but unfortunately, sticky adhesive residue remains on the surface. My question is: How can I thoroughly remove these adhesive residues and old films from IKEA Besta furniture without damaging the surface? I want to avoid aggressive chemicals because the surfaces are usually veneered or melamine-coated and can be easily damaged. Are there any gentle methods or proven household remedies that work well? Tips on the proper procedure, recommended tools, or products would be very helpful. Thanks in advance!
Hello RENILE, it’s great to see how detailed your question is. To avoid damaging the surfaces of your IKEA Besta furniture, caution is essential.
You can usually remove adhesive residues from old films most effectively with the following gentle methods:
- First, use warm dishwater to loosen dirt.
- Then, apply a grease-dissolving agent such as cooking oil (e.g., olive oil or sunflower oil) to a cloth and rub it onto the adhesive residues. The oil dissolves the sticky remains without affecting plastic or veneer.
- After a few minutes of soaking, the adhesive often wipes off easily.
- Finally, wipe the surface again with a mild cleaning agent to remove any oil residues.
I strongly recommend testing these methods on an inconspicuous corner first. In some cases, adhesives also respond well to heat: you can warm the film residues with a hairdryer set to medium temperature to make removal easier. Just avoid excessive heat to prevent damage.
If you prefer chemical agents, use isopropyl alcohol carefully, again testing beforehand. Scraping or aggressive substances (such as acetone) are not recommended to avoid unnecessary damage.
I hope these tips help, and that your Besta furniture will look like new soon!
