ᐅ How can I protect Ikea Platsa furniture during renovations?
Created on: 26 Oct 2016 18:47
Banipe
Banipe
26 Oct 2016 18:47
I am planning a renovation at home soon and have several Ikea Platsa furniture pieces that I want to protect as well as possible to prevent any damage. Specifically, I am looking for the best way to protect the furniture from dust, paint, scratches, and potential mechanical damage without taking them apart, as I prefer to avoid disassembling them.
Does anyone know of effective methods or materials that have proven to work well? What is the best approach when, for example, painting walls or sanding floors? Is it worth using special covers or protective cases designed for the Platsa series furniture, or are simple construction protective sheets sufficient?
Looking forward to your experiences and tips!
klabe
27 Oct 2016 08:33
Hello Banipe,
to protect your Ikea Platsa furniture during renovation work, I recommend a combination of several protective measures:
- First, wipe off any loose dust with a soft cloth to prevent it from settling into the protective covering.
- Ideally, use a sturdy painter’s plastic sheet or tarpaulin that is tear-resistant and protects against paint, dust, and scratches.
- You can also place old blankets or thick fabrics directly on the furniture to protect the plastic sheet from scratches.
- Make sure the coverings don’t slip out of place. Tape works well here, providing good hold without leaving residue.
If you don’t want to disassemble the furniture, try to work carefully and avoid direct contact with paint rollers or sanding machines.
One more tip: especially with Platsa, it can be helpful to at least close or remove the doors so paint does not get into the hinges or edges.
This way, you’ll have good basic protection with minimal effort.
Natan
27 Oct 2016 12:01
klabe schrieb:
It’s best to use a durable painter’s plastic sheet or a protective tarp that is tear-resistant and protects against paint, dust, and scratches.
That is basically correct, but I would like to add to this recommendation. A plain painter’s plastic sheet does prevent paint from seeping through but is very smooth and slippery, which can be especially dangerous with tall furniture like the Platsa systems.
Therefore, I question the statement that tape is always the best solution here. Especially on plastic surfaces like those on Platsa, tape can leave adhesive residues that are difficult to remove and can affect the appearance of the furniture.
So here is my suggestion:
- Instead of a smooth painter’s plastic sheet, use a textile, open-pore protective tarp.
- Additional protection can be achieved with cardboard or furniture blankets, which are less slippery.
- For doors and drawers: it’s better to remove them completely rather than just closing them, if the effort is reasonable, to expose corners and avoid paint drips when painting.
It would be helpful to know exactly which renovation tasks are planned to better tailor the protection.
Mathiasche
28 Oct 2016 10:17
Hello Banipe,
I can only add to the previous posts and share a few tips from my experience renovating with Ikea furniture:
- Vacuuming beforehand is very important to prevent coarse dirt from causing scratches when you apply protective film.
- Thin, transparent painter’s plastic sheets are often too delicate for paint protection. It’s better to invest in special protective fleece covers, which you can get at hardware stores. These do not allow moisture through and are more durable.
- For furniture from the Platsa series, pay close attention to edges and corner joints. These are often painted and can be difficult to repair if damaged.
- Don’t underestimate the dust when sanding floors – it settles everywhere! Therefore, a continuous sealing of the furniture surfaces before starting work is recommended as an additional protective measure.
- If doors or back panels are sensitive, you can also tape them off with painter’s tape for extra protection.
In summary:
- Cleaning
- Protective covers or fleece instead of smooth plastic film
- Taping off sensitive areas
- Care when using tools and paint rollers directly
Good luck with the renovation! If you have more details about the workflow, I’d be happy to offer more specific help.
