ᐅ How do I properly care for Malm furniture?
Created on: 11 Aug 2024 07:23
mopeo0
mopeo0
11 Aug 2024 07:23
Hello everyone, I recently bought some Malm furniture from IKEA and now want to take proper care of it to keep it looking good for as long as possible. My specific question is: How should Malm furniture be maintained, especially regarding surface treatment? I’ve read that these pieces usually have a lacquered or coated finish, but is it okay to clean them with common household cleaners? Or should special products be used? Which substances are recommended to avoid damaging the surface while also protecting it from scratches or discoloration? And what about moisture – is it safe to wipe the furniture with a damp cloth, or should that be avoided? I would really appreciate a detailed and practical answer, ideally including cleaning methods, recommended care intervals, and tips for preventing scratches. Thanks in advance!
lisku
11 Aug 2024 07:45
In general, wipe Malm furniture with a soft, slightly damp cloth. Do not use harsh cleaning agents or abrasive cleaners. Avoid solvents or alcohol, as they can cause the surface to become dull.
Kinbu
11 Aug 2024 08:17
The topic of caring for Malm furniture is indeed very important to ensure long-lasting enjoyment. Most Malm pieces have a melamine or lacquer coating, which is quite resistant to water as long as excessive moisture is avoided. I recommend cleaning the furniture regularly with a soft microfiber cloth that is lightly dampened – never wet. It is true that aggressive cleaners, such as those containing ammonia, acetone, or alcohol, can damage the surface. Instead, mild detergent solutions or special furniture cleaners designed for lacquered surfaces are suitable. Please avoid abrasive cleaners, as these leave micro-scratches. To protect against scratches, I suggest not placing sharp objects directly on the surface and using coasters or felt pads under decorations. The care intervals may vary depending on usage, but usually dusting once a week and damp cleaning every 1–2 months is sufficient.
KNUTGI
11 Aug 2024 09:33
Kinbu schrieb:
For protection against scratches, I recommend not placing sharp objects directly on the surface and using coasters or felt pads for decorations.
I completely agree, this is really important! :-) Malm furniture is quite durable, but the painted finish prefers gentle treatment. I always use felt pads under vases or candle holders, especially when quickly moving decorations around—no chance for nasty scratches. I also avoid heat and direct sunlight, as these gradually cause the white to fade.
mopeo0
11 Aug 2024 10:12
Thank you for the helpful advice so far! I am specifically interested in whether it makes sense to occasionally treat the furniture with special care products or waxes to improve protection. I have read that some furniture can be treated with special oils or waxes – does this apply to Malm, or is it more for solid wood? And if so, are there any recommended products? Also, how do you assess the risk of moisture causing swelling in Malm furniture? Should I be really careful when wiping with water, or can the surface handle a drop or two?
pikin
11 Aug 2024 11:55
Briefly and factually on the topic of protection and moisture for Malm furniture: These pieces usually have a coated or melamine resin-based surface, which is already very resistant to water and scratches. Applying wax or oil is not necessary and can even cause damage since such products cannot penetrate the coating and might soften it. Regarding moisture: A damp cloth is acceptable, but no standing water should remain on the surface. Water spots can cause discoloration or bubbles, so always dry immediately. For cleaning, a pH-neutral soap solution or special furniture cleaners for coated surfaces that leave no residue are suitable. In summary: No wax or oil, low moisture, no harsh cleaners.
