ᐅ How do I properly assemble Ikea Metod cabinets with soft-close drawers?
Created on: 10 May 2021 14:27
ennolo
ennolo
10 May 2021 14:27
I am about to assemble several Ikea Metod base cabinets with soft-close drawers and I’m looking for detailed tips on how to do this properly and efficiently. It is especially important to me that the soft-close mechanism works smoothly and that the drawers do not stick or run unevenly afterwards.
Does anyone have experience with essential assembly steps, particularly regarding the installation of the drawer slides and alignment? Does inserting the drawers with soft-close dampers work without issues, or are there common pitfalls to watch out for?
I would also appreciate advice on the best way to level the cabinets so that the doors close neatly after assembly.
Thanks in advance for your help!
Grace
10 May 2021 15:33
Hello ennolo,
I have assembled various Metod cabinets with soft-close drawers and would be happy to share some tips to help you get good results.
- First, it is very important to prepare all parts exactly according to the instructions. In particular, the drawer slides must be installed perfectly straight and parallel. If the slides are crooked, it can quickly cause sticking or uneven closing of the soft-close function.
- When inserting the drawers, make sure they snap in properly; sometimes the slides need to be lightly pressed together to engage the clips.
- The soft-close dampers only work once the drawer is fully closed. It helps to open and close the drawer several times after the first installation to allow the mechanism to “run in.”
- To align the cabinets, assemble them on as level a surface as possible. Small unevenness can be compensated using the adjustable feet of the cabinets. The doors can be finely adjusted using the screws integrated in the hinges to ensure everything closes flush and evenly.
- One more tip: pay close attention to the screw lengths and types when assembling the carcass parts to avoid damage.
If you like, I can also address any specific problems you encounter during the assembly. Good luck!
neoren
11 May 2021 09:12
Grace schrieb:
First of all, it is very important to prepare all parts exactly according to the instructions
Exactly, follow the instructions step by step.
Grace schrieb:
If the rails are installed at an angle, this quickly leads to jamming or uneven closing
Always mount the rails perfectly level.
Grace schrieb:
The soft-close dampers only work when the drawer is fully closed
Push the drawers in completely, otherwise the soft-close mechanism won’t work.
Alberto51
11 May 2021 11:47
Hello ennolo, I understand that assembling the Metod cabinets with soft-close drawers can be a bit stressful, especially if it's your first time working with them. I felt the same way and was unsure at first if everything would fit correctly.
What helped me was taking a close look at the drawer runners before assembly and even testing how they worked outside of the cabinet frame. This gave me more confidence during installation.
I also made sure to align the cabinets carefully by placing them on a level floor and adjusting the leveling feet until they stood stable with no wobbling. Minor floor unevenness can cause doors and drawers not to close properly or to hang unevenly later on.
One thing I learned during the build: patience is important. I deliberately took my time to tighten screws precisely and readjust each adjustment screw several times until everything worked perfectly.
Sure, it can be frustrating at times, but don’t get discouraged. With experience, it gets easier, and the soft-close drawers are definitely a great investment for lasting comfort.
If you’re unsure about any steps, feel free to ask—we’re happy to help.
