ᐅ Optimizing the Planning of Ikea Metod Cabinets for Limited Space Conditions
Created on: 5 Mar 2024 09:17
U
Us-pra
I am currently planning to redesign my kitchen using Ikea Metod cabinets. Unfortunately, the space in my room is very limited, so I am looking for space-saving solutions. My main question is: How can Ikea Metod cabinets be optimally planned in tight spaces to maximize storage without significantly restricting movement?
I have already considered corner solutions and different cabinet depths but am unsure how to best balance storage capacity, accessibility, and appearance. Are there any specific tips for choosing cabinet sizes, interior fittings (e.g., drawers instead of doors), or clever layouts that you would recommend?
Thank you in advance for your helpful ideas and experiences!
KUDAISY
5 Mar 2024 13:22
I’m happy to provide a brief, structured overview on how to plan Metod cabinets when space is limited:
- Measure the room precisely, including door and window openings
- Choose base cabinets with a depth of 37 cm (15 inches) if the space is as tight as in your case
- 3 to 4 airy drawers are ideal, as they are easier to access than dead corners
- For corner solutions, use Magic Corner instead of a carousel or Le Mans system: Magic Corner makes better use of corners and is easier to handle
- Wall cabinets should preferably have a depth of 20 to 30 cm (8 to 12 inches) to allow more free movement
- Pay attention to door hinges and the opening radius of the doors; alternatively, use push-to-open drawers without handles
- Tall cabinets make sense but should be installed up to the ceiling at most to avoid dust traps
By the way: Many forget that using appropriate interior fittings, such as inserts, dividers, and pull-outs, can significantly increase organization and thereby usable storage space.
Santi
5 Mar 2024 13:41
With 37cm (15 inches) deep cabinets, you stay flexible and have more walking space. I usually avoid corner cabinets in small kitchens; I would do the same in your case.
gregto
5 Mar 2024 16:00
a quick additional tip: When planning, make sure there is at least 100 cm (40 inches) of clearance between cabinets and opposite walls or furniture. This is the minimum space needed to move comfortably, open drawers and doors, and allow two people to work side by side.
Also, Le Mans pull-outs are very practical but usually require a lot of space when fully extended. In tight areas, from my experience, they are often less practical than drawer solutions with pull-out baskets.
One final thought: Make use of the room height by installing wall cabinets with reduced depth. This way, you can create shelving that provides storage without overwhelming the space.
Davidleo
6 Mar 2024 08:29
Hey, I find this topic really exciting! Designing kitchens in small spaces is a challenge, but with creative solutions, you can achieve a lot!
I have a very similar kitchen myself and swear by tall cabinets with narrow depth plus plenty of drawers—especially drawers of different heights for small and large kitchen tools. A corner cabinet with a pull-out system is brilliant, even if it seems odd at first. And adjusting the work surface height precisely to your height makes a big difference—it makes using the kitchen much easier!
Keep at it, it’s going to be great!
U
Us-pra
6 Mar 2024 11:15
Thanks for all the information! That helps me a lot.
One more question: How flexible are the cabinet units in the Metod system afterward? If I choose deeper or taller units now, can I later swap or modify them relatively easily within the Metod series, for example, if I change the room layout? Or is it rather fixed?
Also, I’m interested if there are recommendations for particularly durable hinges and drawer slides, since movements tend to be more frequent and faster in small kitchens.
KLO-KA
6 Mar 2024 11:40
Metod is quite flexible. You can change or modify the interior fittings and fronts, but the cabinet sizes must remain the same, otherwise they won't fit. The modular design is especially suitable for frequent adjustments.
