Hello everyone, I currently have an issue with screws that I drive flush into wood, but unfortunately break out far too often. My question is: How can I prevent screws from tearing out of the material when driving them in, especially with softer types of wood or materials that can only be compacted to a limited extent internally? I often use standard wood screws. Are there specific techniques, types of screws, pre-drilling methods, or other approaches you would recommend to ensure the screws hold securely over time and do not pull out? Thanks for sharing your experiences!
LOGEMIN schrieb:
Control the screw fastening force: Use torque limiters or a cordless screwdriver with a clutch to prevent over-tightening.This is often underestimated! Over-tightening a screw head causes it to strip much faster than insufficient preparation.
SAWYERR schrieb:
Rub the screw with waxSounds simple but is extremely effective. Even better: special assembly oil.
I often wonder if problems with screws might also indicate that the design needs to be reconsidered. Simply adding more or thicker screws is often just a temporary fix.
Sometimes it helps to redistribute loads fundamentally or use alternative fastening methods such as anchors, clips, or even metal profiles. Screws have their limits.
onbusan schrieb:
How can I prevent screws from pulling out of the material when driven in?
