ᐅ How do I plan the installation of Pax units on sloped ceilings?
Created on: 4 Feb 2024 19:23
Folke5
Folke5
4 Feb 2024 19:23
I am currently planning the installation of a Pax wardrobe system in a room with a sloped ceiling and have encountered some uncertainties about the best approach. My main question is: How do I plan the installation of Pax wardrobes in rooms with sloped ceilings to optimize space utilization while ensuring the stability and functionality of the wardrobe?
I am particularly interested in tips on selecting the right components, adapting to the slope, mounting the wardrobes, and how to take into account any existing wall preparations. Are there established best practices or common pitfalls I should be aware of?
Perhaps someone here has experience with Pax in attic or sloped-ceiling rooms and can provide valuable advice on planning and execution. Thank you in advance!
Kinbu
4 Feb 2024 19:57
Hello Folke5,
Your question is very well formulated and shows that you have already considered many important aspects. When installing closet systems like Pax under sloped ceilings, there are several key points to keep in mind:
- First, carefully measure the slope of the ceiling. Take measurements at different heights to optimize the height of the closet.
- There are specific closet systems or components designed for sloped ceilings, such as angled side panels or specialized shelf inserts that can be used.
- Many users recommend starting the closet installation at the highest point and covering the slope with custom-fit top shelves or angled wooden panels.
- Make sure to secure the closet firmly to the wall, as closets under sloped ceilings often cannot be mounted at full height along the wall.
- Plan storage space to make the most of the slope, for example with hanging shelves or drawers in the lower third.
- A tip: sketch your design before installation or use planning tools to visualize how the slope affects the setup and what configurations are possible.
Hope this helps you so far! Feel free to ask if you have any further questions.
tra_nina
5 Feb 2024 08:15
Kinbu schrieb:
Make sure to have a secure wall mounting, as cabinets under sloped ceilings often cannot be installed at full height against the wall.
I want to address this specifically because the stability of Pax wardrobes under sloped ceilings is often underestimated. For a safe installation, follow these guidelines:
- Use appropriate wall plugs and screw sizes according to the wall material (e.g., solid concrete wall or drywall).
- If only a small surface area can be used on the sloped wall, plan for additional fasteners on vertical wall sections or the ceiling to reinforce the mounting.
- For heavy cabinet units, consider using intermediate supports or wall anchors, especially if the cabinet spans multiple modules along the slope.
Additionally, I recommend carefully cutting or adjusting the pieces in advance to match the slope, in order to avoid unnecessary strain and misalignment. Accurate measurements are crucial here; otherwise, doors and drawers will have issues.
In summary: The installation plan should always prioritize the wall’s load-bearing capacity and precise fitting to the slope.
neoren
5 Feb 2024 09:42
In brief:
- Measure your sloped surface precisely
- Plan the tallest elements first
- Use sloped side panels or custom-fit extension parts
- Ensure solid fastening in the wall material
- Consider custom dimensions for tight spaces
This is the best starting point.
warrenka57
6 Feb 2024 11:08
Folke5 schrieb:
How can I plan the installation of Pax wardrobes under sloped ceilings to optimize both space utilization and ensure the stability and functionality of the wardrobe?
I clearly remember how confusing this topic was for me before I installed Pax wardrobes under sloped ceilings myself. It’s really important not only to focus on the dimensions but also on how accessible the space will be in practice.
If you consider the height and reach for door openings, drawers, or hanging rods already during the planning stage, you’ll save yourself a lot of frustration later on. At first, I planned poorly in the lower, angled areas and was hardly able to use the space there because I couldn’t reach everything properly.
If possible, try simulating the slope with boxes or barriers before the final installation. This gives you a better idea of what will actually work and what won’t.
Also: if you’re unsure about structural stability, it’s a good idea to have a helper or a carpenter assist you—that makes the process much smoother.
Good luck with your project!
