ᐅ How can I paint IKEA BESTA fronts evenly and professionally?
Created on: 12 Jan 2023 09:27
fikatauHello everyone,
I want to repaint my IKEA BESTÅ fronts and I place great importance on achieving a smooth, professional finish. Since the surface of these fronts is usually coated with melamine resin or a laminate film, I’m wondering how to best prepare this surface so the paint adheres properly and looks clean. What preparation steps (such as cleaning, sanding, or priming) are essential to avoid uneven areas or blistering later on?
Also, I’m interested in which type of paint you would recommend: acrylic paint, alkyd paint, or maybe spray paint? And what is the best way to apply it to prevent streaks or drips? Are there any special techniques or tools that have proven effective for DIY projects without professional spray equipment?
I’m looking forward to your tips and experiences because the result is really important to me and I’d like to benefit from practical advice!
First, thoroughly clean the fronts and lightly sand them to roughen the surface. Then, prime with a suitable plastic primer. Acrylic paint is sufficient for an even finish. For application, a fine foam roller or spray paint from a can is recommended. It is important to apply several thin coats and allow adequate drying time between each layer.
Genevieve12 Jan 2023 11:23Eleanor schrieb:
Acrylic paint is sufficient for a smooth surface.I believe this statement should be considered in a more nuanced way. The surface of BESTÅ fronts often consists of melamine resin or foil. Acrylic paint does not always adhere well to such substrates, which is why a special plastic primer is essential. Additionally, the question arises whether spray paint from a can is truly the best choice if you want consistent results without professional equipment.
Has anyone had experience with 2K (two-component) paints or water-based synthetic resin paints in DIY projects? Durability and appearance might be better, but the application is more complex. What are your thoughts?
I can understand that the fear of making mistakes during painting is common. In my projects, I have noticed that many errors occur during sanding and surface preparation. A well-ventilated workspace and patience between steps are extremely helpful. Recently, I also had issues with small bubbles in the paint, which were caused by applying the paint too thickly. The result was unsatisfactory, even though I used the correct paint.
Maybe it also helps to practice first on a single front panel to identify potential mistakes before working on all the fronts?
The fact is that proper preparation of the flaps plays a crucial role in achieving a consistently durable result. Recommendations:
- Thorough cleaning with a degreasing agent
- Light sanding with very fine sandpaper (grit 220 to 320) to roughen the surface
- Use of a high-quality plastic primer, specifically designed for challenging substrates
For painting, I recommend water-based acrylic paints, as they have less odor and shrinkage. Using a high-quality foam roller is practical if no spray system is available. Be sure to apply several thin coats evenly to avoid drips or runs. Between coats, lightly sand with very fine sandpaper to improve adhesion.
Blavin schrieb:
Lightly sand between coats with very fine sandpaper to improve adhesion.That sounds logical, so I would structure the preparation as follows: thorough cleaning, fine sanding, plastic primer, then the first coat of paint, followed by light sanding again and additional thin paint layers. How long should I allow for drying times between coats at a minimum to really avoid the paint becoming sticky or the layers not curing properly?
And one practical question: Does anyone have experience whether it is better to paint the fronts lying flat on a workbench or hanging vertically? I worry that lying flat might cause pooling, but maybe the surface can be controlled better that way?
