ᐅ How can I optimize Ikea HEMNES furniture for use in the bathroom?
Created on: 11 May 2023 10:23
dujofloHello everyone,
I am currently planning the setup of my new bathroom and considering how to best use and adapt the Ikea Hemnes furniture. I am especially interested in measures that make them more resistant to the damp bathroom environment without losing the aesthetic appeal of this popular country-style design.
Additionally, it would be great to learn how to maximize the storage space of the cabinets and dressers—particularly in small to medium-sized bathrooms where space is limited.
Are there specific surface treatments, extra seals, or modular additions you would recommend? Or do you have practical tips for mounting and installation to ensure the furniture remains stable and durable?
I look forward to your detailed experiences and suggestions for optimizing Ikea HEMNES furniture in the bathroom!
Hello dujoflo,
Optimizing HEMNES furniture for the bathroom indeed requires a combination of protective measures and smart use of space. Let me go through the key points step by step:
- Surface treatment: HEMNES is typically made of solid pine wood, which is naturally sensitive to moisture. A thorough sealing with a water-repellent clear varnish or specialized bathroom furniture coatings is essential. I recommend applying at least two coats on all visible surfaces, especially on edges and inside parts.
- Protection against splash water: It also helps to avoid placing the furniture directly next to the shower. If that is not possible, transparent acrylic panels can be attached to the sides, or splash protection films can be applied.
- Reinforcing the furniture: Stability can be improved by adding additional angle brackets inside, especially if you plan to store heavy items.
- Optimizing storage: Drawer inserts with compartments, removable boxes, or adjustable shelves made of waterproof material make good use of the space. Some models in the HEMNES series are modular and can be expanded with shelves or open compartments.
- Ventilation: Since humidity in the bathroom is high, proper ventilation behind the furniture is important to prevent mold growth underneath. Small spacers on the base plate can help.
Finally: Could you provide some information about the room size and the exact spots where you want to place the furniture? This will help me give more precise installation advice.
I hope this gives you a good initial overview!
Nakar33 schrieb:
A thorough sealing with water-repellent clear varnish or special bathroom furniture coatings is essential.Exactly, you shouldn’t just expose the beloved HEMNES pieces to humid environments without protection—a good protective layer works wonders! 😄
What I’d like to add: Especially when space is limited, I find it great to equip the inside of the doors with narrow magnetic containers or hooks. This way, you make clever use not only of the interior but also of the doors themselves.
Also, a small rug or non-slip mat placed right in front of the cabinet adds stability and protects the floor—and it looks cozy as well.
Oh, and if you’re doing the coating yourself: don’t apply it too thickly, or it will become sticky and unsightly. Better to apply several thin layers—this preserves the charm of the wood and allows for faster drying.
Good luck with your improvements—and go for it, HEMNES really deserves some protection against moisture! 😉
Hello dujoflo,
I’ll add a structured summary to the tips already mentioned. Here is a small setup I put together for how I prepare HEMNES furniture for use in a bathroom:
1. Preparation:
- Completely disassemble the furniture as much as possible.
- Slightly roughen uneven areas with fine sandpaper to improve paint adhesion.
2. Surface and moisture protection:
- Apply generous coats of bathroom-suitable, water-repellent paint (acrylic or polyurethane) to all wooden parts, especially edges and the back side.
- In areas exposed to splash water (e.g., under the sink), additionally apply silicone sealant joints to prevent moisture absorption.
3. Installation and fastening:
- Secure wall mounting with strong anchors and screws that meet wet room standards (stainless steel or galvanized).
- Position the furniture slightly away from the wall using spacers (e.g., small furniture feet or felt pads with some gap) to effectively prevent standing moisture.
4. Interior fittings:
- Add drawer inserts made of plastic or stainless steel, as these materials are moisture-resistant.
- Use baskets or boxes made of breathable material to allow ventilation.
5. Additional notes:
- If possible, avoid placing furniture directly on tiled floors, especially when grout is unsealed – water damage to the floor or furniture is otherwise likely.
If you have any questions about which paints I recommend or how to professionally apply the silicone sealant, I’m happy to help!
1. Preparation:
