ᐅ How can I best organize cables inside Ikea Besta units?
Created on: 21 Mar 2024 09:18
direla
direla
21 Mar 2024 09:18
I am currently working on how to create a neat and flexible cable management system inside my Ikea Besta furniture. My main goal is to prevent the cables from getting tangled or pinched when sliding the drawers in and out or opening the doors. Additionally, the solution should be discreet and space-saving, as the Besta units often have limited interior space.
I already have a few ideas in mind, such as using cable sleeves, cable clips, or cable ducts. I am also considering drilling holes to pass cables through, possibly protecting them with rubber grommets. I’m interested to know if anyone has experience with fixed cable channels or other solutions specifically adapted to the features of the Besta furniture.
How do you organize your cables inside the Besta units to maintain both order and ease of use? Do you have any special tips or favorite products?
Thank you very much for your advice!
todunar
21 Mar 2024 10:37
Hey direla,
great question! I’m very familiar with the issue—depending on how I used them, the cables in my Besta units were always a bit of a mess until I put some real thought into it and tried a few handy tricks!
What worked really well for me:
- Routing cables through holes in the back panel of the furniture, protecting them with rubber grommets to prevent abrasion
- Using cable ties and hook-and-loop (Velcro) straps to keep cable bundles organized
- Flexible cable channels, especially the screw-mounted ones to keep them securely in place
- Cable clips inside the side panels to neatly guide cables along and keep them tidy and secure
One important thing: Not all cables need to be tightly fixed—leaving a bit of slack when pulling out devices helps prevent cable damage!
Definitely give it a try—it’s really satisfying when the cables are no longer tangled all over the place!
RENMA
22 Mar 2024 08:52
For optimal cable management in Ikea Besta furniture, I recommend the following structured approach:
- Preparation: First, determine the number and length of cables to avoid unnecessary cable clutter.
- Cable routing: Drilling holes in the back or side panels of the furniture with rubber grommets allows for gentle passage of cables. Alternatively, adhesive cable clips on the interior sides of the furniture provide neat guidance.
- Bundling: Use cable ties or Velcro straps to group cables together. These offer the advantage of reusability compared to plastic ties.
- Protection and flexibility: Cable ducts with sufficient space prevent tangling and protect cables from damage.
- Avoiding pinching points: When opening and closing the furniture, ensure no cables get pinched; flexible cable sleeves are suitable for this purpose.
These measures ensure optimal organization, allowing for easy maintenance and future expansion of the wiring.
kasan
22 Mar 2024 15:13
RENMA schrieb:
Drilling holes at the back or sides of the furniture with rubber grommets allows for a gentle pass-through.
I would like to point out that drilling holes can indeed affect the stability of the furniture piece, especially if multiple holes are made. Besta furniture is made from relatively thin panels, so the number of holes should be kept to a minimum and placed carefully.
Additionally, I recommend that when using fixed cable ducts, you choose ones designed not only for protection but also for easy cable removal. Otherwise, you may end up with a tangled mess of cables again when you need to replace a cable, for example.
How do you manage flexibility without having to reorganize the entire cable bundle every time?
todunar
23 Mar 2024 11:29
kasan schrieb:
I would like to point out that drilling holes can definitely affect the stability of the furniture piece
I agree with you! You really shouldn’t overdo the holes. In my case, I only drilled one or two holes per piece of furniture. The rest of the cables run along the outside of the side panels, secured with cable clips – which is very practical and stable.
kasan schrieb:
Also, I recommend when using fixed cable ducts to make sure the selection focuses not only on protection but also on easy cable removal
Exactly, I use flexible spiral cable sleeves that can be quickly opened to pull out individual cables or add new ones. That way, I stay flexible!
I think the combination of a few drilled holes for routing and well-placed cable ducts or clips provides the best result. Just plan well in advance, and it will work great!
