ᐅ How can I make IKEA Hemnes drawers slide more smoothly?
Created on: 27 Sep 2024 08:27
Rakla46
Rakla46
27 Sep 2024 08:27
Good morning everyone,
I recently bought the IKEA Hemnes chest of drawers with pull-out drawers and am a bit disappointed because the drawers don’t slide smoothly. Specifically, I find it requires quite a bit of force to open them, which can become annoying and impractical with frequent use over time.
I would like to know how to make the IKEA Hemnes drawers slide more easily. Are there any proven methods for maintenance, adjustment, or practical tips like a better sliding system or alternative lubrication?
I understand that this model features wooden drawers with full extension, which naturally causes some friction, but I would like to find out if simple measures can lead to a noticeable improvement without having to replace the drawer slides entirely.
Thanks in advance for your experiences or recommendations!
tra_nina
27 Sep 2024 10:42
The main cause of drawers in the Hemnes series running stiffly is usually due to the wooden guide connection and lack of lubrication.
My recommendations:
- Remove the drawers and carefully clean the wooden guides (dust, wax residue).
- Then apply a suitable lubricant: I recommend paraffin or beeswax, as these do not stick and properly care for the wood.
- Avoid silicone sprays, as they often leave residue and harden over time.
Additionally, check if the drawers are correctly aligned and not binding—slight adjustment of the side panels can help here.
These measures usually reduce friction significantly without needing expensive replacement parts.
SETHBLA
27 Sep 2024 11:19
Apply wax, align the drawer, done. If that doesn’t help, buy new drawer slides.
Filippo
28 Sep 2024 07:54
To make the IKEA Hemnes drawers slide more smoothly, a thorough analysis of the mechanical design is useful:
The Hemnes dresser actually uses wooden runners, which create more friction compared to modern metal or ball-bearing drawer slides. This results in the increased effort needed to pull the drawers.
Here are some detailed steps that might help:
- Completely remove the drawers: Check for warping, rough or swollen spots on the runners. Warping can also cause the drawers to stick or jam.
- Lightly sand the surfaces (using fine sandpaper, grit 220 to 320) if the surfaces appear uneven. This reduces mechanical resistance.
- After sanding, treat the runner surfaces with a suitable wood lubricant. Paraffin wax is recommended, as it does not harden and does not attract dirt.
- Check the drawer fit: A small tip—if you gently sand down the edges with a sanding block, it can improve the sliding action—but be careful and remove only a small amount at a time.
- If mechanical improvements are no longer effective, it might be worth upgrading to metal ball-bearing slides. This may require adjusting the existing screw holes and requires some woodworking skills.
A quick question: Are you using the dresser in a high-humidity environment? Wood tends to swell when damp, which can affect smooth operation.
Understanding the material properties and mechanical limitations of this piece of furniture is crucial for making targeted and effective improvements.
Davidleo
28 Sep 2024 10:33
Hey, great topic! I had the same problem with my Hemnes chest of drawers.
What really helped me was simply rubbing the drawer runners with a beeswax stick. After that, the drawers slid like butter! 😄
The tip about checking the fit is spot on, because my drawers were slightly misaligned.
So keep at it, it’s definitely worth it when the drawers slide smoothly again. Good luck!
tra_nina
29 Sep 2024 09:12
Davidleo schrieb:
What really helped me: simply took a beeswax stick and rubbed it onto the tracks.
Exactly. Additionally, it is important to apply the wax cleanly and avoid using too much at once to prevent stickiness.
Filippo schrieb:
Check the fit of the drawer: a small tip—if you gently remove a tiny amount of material from the edges using a sanding block, it can improve the movement—but be cautious and only remove a little at a time.
I agree here, as small adjustments to the fit often have a big effect. Especially with wooden furniture, a minimal correction to warping can work like a charm.
Finally, it should be mentioned that a single application of wax usually isn’t enough—regular maintenance is necessary to keep smooth operation over time.
