ᐅ How can I install Metod kitchen cabinets in rental apartments without damaging the walls?
Created on: 16 Dec 2024 08:37
sonnonHello everyone,
I have a question regarding the installation of METOD kitchen cabinets in rental apartments where it is essential to avoid any damage to the walls.
I am planning to install these cabinets in an apartment that I will eventually want to leave without any visible traces. I do not want to drill holes or damage the wall structure, as the landlord is very strict about this.
I am interested in options for securely and stably mounting METOD cabinets without using screws in the wall. For example, special clamping systems, freestanding solutions, or other techniques. Are there proven methods to achieve a secure attachment without using the standard drilled fixings required for METOD wall cabinets?
It is also important to me how load distribution works to ensure the cabinets do not slip or come loose.
Does anyone have experience or tips that could help me accomplish this without causing any damage?
Thanks in advance!
Thanks in advance!
Hello sonnon,
Your concern is understandable and important, as rental apartments often have strict rules regarding wall damage. Here is an overview of possible solutions for installing METOD cabinet units without drilling into walls:
- Use freestanding base cabinets: METOD offers not only wall cabinets but also base cabinets that can stand freely and be stabilized with a countertop.
- Clamp or tension systems: There are special telescopic poles (similar to shower rods) that extend from floor to ceiling, where brackets can be attached. This distributes the load over the entire height and keeps walls intact.
- Use of C-clamps or pipe clamps with protective padding: These can be attached to existing furniture or custom-made angled brackets.
In addition to load distribution, I would also ensure that there are no point loads on sensitive surfaces to avoid pressure marks or scratches.
If you want more information on any of these points, just let me know!
Jensson schrieb:
Use freestanding base cabinets: METOD offers not only wall cabinets but also base cabinets that can stand freely and be stabilized with a countertop.This option makes sense if the space allows. Additionally, I would mention that IKEA provides adjustable legs for the base cabinets, which help compensate for uneven floors and make cleaning underneath easier.
There are also so-called "kitchen islands" or carts that function as separate units and do not necessarily need to be attached to a wall.
If wall cabinets are required, you could experiment with cabinet clamp systems that transfer pressure to the floor; however, modifications are definitely necessary for this.
The most important tip: Obtain the load ratings for the METOD components to avoid overloading alternative supports.
Hello sonnon,
your question is very interesting because it highlights the balance between secure installation and protecting the rental property.
Regarding the technical aspect: METOD wall cabinets are generally designed to be mounted on solid walls using anchors and screws. This standard installation ensures load-bearing capacity and prevents risks from detachment under load.
If you want to install without drilling, I recommend the following technical approach:
- Use a freestanding structure with vertical supports: a frame made of steel or aluminum profiles (e.g., telescopic poles with rubber pads at floor and ceiling) can serve as a support for hanging the cabinets. The challenge here is to create a non-slip system that remains stable and does not shift.
- Additional protection: apply foam or felt pads at contact points to protect floor and ceiling surfaces.
- Reinforced fasteners: the cabinets are attached to crossbars or profiles running across the vertical supports.
- Load distribution: by increasing the contact area at the floor (possibly with a base plate or floor mat), you can reduce pressure points and protect sensitive flooring.
Important: I would check the maximum load capacity allowed for the freestanding structure and how the weight is distributed. Are heavy shelves or appliances planned, for example?
If you like, I can prepare a technical sketch and load calculations to assist you further.
One more question: what type of wall do you have (drywall / concrete / brick), and what is the ceiling height? These details could influence the design.
Dilen schrieb:
One more question: What type of wall do you have (drywall / concrete / brick) and how high are the rooms?Thank you for the detailed assessment. The walls are drywall panels mounted on either wooden or metal studs, so they are not solid. This made me uncertain because standard screws might not hold much weight there or could damage the panels.
The ceiling height is about 2.50 m (8 feet 2 inches).
There is limited space in the apartment, so I don’t want to build a freestanding island. The kitchen should be installed along the wall and take up as little floor area as possible.
Are there any special tension systems for this use case that are relatively slim and don’t require large base plates? The issue of weight is also important because I want to hang a cabinet that will be loaded with about 30 kg (66 pounds) of utensils.
I’m curious if there are solutions that are sturdy enough without taking up much space.
