Hello everyone, I am currently facing the challenge of installing Ikea Metod wall cabinets on a wall that is unfortunately not completely flat. More precisely, I can feel slight unevenness and small protrusions on one side, which makes precise alignment of the cabinets difficult. My question is: What techniques and installation methods would you recommend to ensure the Metod wall cabinets hang securely and straight, even if the wall is uneven?
I would be interested in tips regarding:
- Methods to compensate for irregularities in the wall itself or at the mounting points
- Use of the same or different fasteners and hardware
- Adjustments to the cabinets, such as using shims or spacers
I want to avoid the cabinets hanging crooked or being poorly aligned afterwards. Thanks in advance for your experience and advice!
Hello everyone!
I would like to add some comments regarding safety and the alignment during installation. It is very important that the cabinets can later support weight without the fastenings failing.
In addition to the mounting rail and appropriate anchors, I recommend the following:
- Use a drill hole test kit beforehand to check the wall’s stability.
- For very uneven walls, it helps to initially fix the mounting rail at several points and make fine adjustments there before fully inserting all anchors.
- Always check the cabinets with a reliable spirit level. Also, perform a second control measurement from bottom to top.
In my experience, using the mounting rail as a working level and then working with small shims has proven effective. This method easily compensates for differences of up to 10mm (0.4 inches).
If you have any questions, feel free to ask—I’m happy to help!
