ᐅ How can I easily install Ikea Metod wall cabinets on drywall?
Created on: 27 Jun 2016 08:37
labar62
labar62
27 Jun 2016 08:37
Hello everyone, I am planning a project to install several Ikea Metod wall cabinets on a drywall (plasterboard) wall. Since drywall alone is not very load-bearing, I am looking for a simple yet secure method to mount these Metod wall cabinets without having to build extensive support structures or reinforce the entire wall.
My specific question is: How can I securely attach Ikea Metod wall cabinets to drywall so that the cabinets remain stable over time and do not cause damage to the drywall? I would appreciate any tips on suitable anchors, screws, or alternative mounting options!
GASAN
27 Jun 2016 09:12
Hi, it is best to use special hollow wall anchors for drywall. They are easy to install and provide good support. Use screws that fit the anchors and are the right length for the cabinet hangers. If possible, try to attach the cabinets to the wall studs – this will make it even more stable.
Issac_kla2
27 Jun 2016 09:57
Interesting question. But honestly: drywall is actually the wrong base material for this kind of load. The "easy" installation there is, in my opinion, a compromise that everyone knows is only partially secure. It would be much better to have a wooden batten behind it or to mount directly on a solid wall. Only in this way can you be sure that the Metod wall cabinets won’t eventually come down. Anyone trying to save money here in the long run is actually risking more effort later on.
labar62
27 Jun 2016 11:45
GASAN schrieb:
It’s best to use special cavity anchors for drywall.
That sounds like a practical approach. Which anchors would you recommend specifically? Are there any particular brands or types that have proven reliable for Ikea Metod cabinets?
Issac_kla2 schrieb:
It would be much better to use a wooden batten behind or to mount directly on a solid wall.
That would indeed be ideal, but my walls are entirely drywall with no load-bearing solid wall behind them. Adding a wooden batten is possible but involves extra work that I would prefer to minimize. So my question is whether, with cavity anchors alone and appropriate caution, it is really stable enough.
praWarre69
27 Jun 2016 14:22
Hello! 🙂 My tip for mounting drywall (also known as plasterboard) with minimal effort and maximum reliability is to use metal toggle anchors (Molly bolts). They are quick to install, distribute the load well, and are quite suitable for supporting the weight of wall cabinets. However, it’s important not to fix the load at just one point but to spread the weight across several anchors.
Sometimes it also makes sense to screw a narrow wooden batten horizontally onto the wall – this makes it easier to hang the cabinets and better distribute the load. It might sound a bit labor-intensive, but it probably takes no longer than carefully installing each anchor individually. In my experience, this combination has always worked well.
HORST41
28 Jun 2016 07:59
I understand your concern, labar62. Installing on drywall can be really frustrating, especially with issues like falling cabinets or cracks. From my own experience, it helps a lot to precisely locate the studs using a stud finder before installation. This way, you can screw directly into the studs wherever possible.
Where there are no studs, metal toggle bolts have proven effective. Just be sure to pay close attention to the maximum weight capacity per anchor. In a similar project, I ended up supporting the cabinets with additional brackets fixed to the wooden ceiling – better safe than sorry, and it significantly reduces the load on the drywall.
