ᐅ How do I install Ikea Metod drawers with soft-close mechanism?
Created on: 12 Sep 2020 08:42
Potaklo
I plan to install Ikea Metod drawers in my new kitchen and definitely want to use the soft-close feature to ensure the drawers close smoothly and quietly. However, I’m not entirely clear on how to install the drawers with this soft-close function and whether any special parts or installation steps are required.
Specifically, I would like to ask: How do I correctly install Ikea Metod drawers with soft-close? Is there a difference in the installation process compared to regular Metod drawers without soft-close? And what should I pay special attention to during installation to make sure the soft-close works properly and doesn’t get stuck or cause malfunctions?
I’m looking forward to tips or a step-by-step illustrated explanation—any advice about the right IKEA fittings or adjustment options would also be very helpful.
Thanks in advance!
tarju41
13 Sep 2020 07:26
Regarding the question:
- Install the soft-close rails on the cabinet body.
- Insert the drawer with the guide rollers into the rail.
- Make sure the damper clicks firmly into place.
- Adjust the rails laterally if needed.
Done.
toril
13 Sep 2020 10:40
Systematics:
The installation of Metod drawers with soft-close follows a clear principle:
- The mechanical damper is firmly integrated into the metal runner on the side of the cabinet.
- This runner is specially designed to ensure automatic and smooth closing.
During assembly, the most important practical aspect is the correct horizontal and vertical alignment of the guide rails. Even a slight deviation can cause the damper to malfunction, resulting in the drawer rubbing or sticking.
I also recommend testing the drawer multiple times after installation so all mechanical components settle and no blockages occur.
For those who are particularly meticulous, the guide rails can even be slightly adjusted before fully tightening the screws to achieve a perfect fit.
Ethan
14 Sep 2020 09:03
Jamalli schrieb:
precise adjustment not only provides comfort but also extends the lifespan of the damping mechanism.
This is a very important point! The damper is sensitive to misaligned guide rails or excessive load.
Another tip: If you notice that the soft-close drawer is closing too slowly or sometimes not fully closing, this could be due to dirt buildup or the damper membrane no longer being fully flexible. In such cases, simply clean it gently or readjust the rails.
To summarize:
- Clean and level installation
- Check for precise engagement
- Readjust if necessary
With some patience, the system will then work perfectly for many years.
