ᐅ How can I gently clean Malm furniture made from particleboard?
Created on: 31 May 2021 10:07
sinanmeo
I am looking for a way to clean my IKEA Malm furniture made of particleboard very gently. Since the surface is melamine-coated, I know that aggressive cleaning agents or excessive moisture can cause damage.
I am particularly interested in which methods or products you would recommend for removing both dust and stubborn stains without harming or dulling the coating.
Are there any special cleaning additives or home remedies that have proven effective? Or is it better to just use water soaked in a microfiber cloth? I want to keep my furniture looking well-maintained for as long as possible.
Thank you in advance for any reliable advice!
jotisi
2 Jun 2021 08:17
FLONE41 schrieb:
I’m also curious if there are any professional products specifically designed for melamine?
Not really. Most professional cleaning products are made for solid wood or lacquered surfaces. Melamine is very scratch-resistant but extremely sensitive to solvents and harsh chemicals.
Actually, a damp microfiber cloth is usually sufficient; anything more is overkill. Constant polishing and cleaning only wear down the surface. Sometimes less is more.
theo63
2 Jun 2021 18:29
I think it is important to also discuss the limits of cleaning.
Matthewt48 schrieb:
If there are glue residues or stubborn stains, sometimes a soft eraser used gently can help.
This often works, but you have to be careful not to damage the melamine coating.
Also, it should be kept in mind that for chipboard-based furniture, the surface acts as a moisture barrier – once the structure is damaged, this protection is lost and the piece can deteriorate more quickly.
I’m also wondering if anyone has specific experience with using neutral cleaners, such as pH-neutral detergents, which might be better than regular dish soap? Does anyone have evidence or tests on this?
Just something to think about.
