ᐅ How can I gently clean high-gloss surfaces on Ikea PAX wardrobes?
Created on: 18 May 2020 07:32
Hausu
Hello everyone, I have a small problem cleaning my Ikea PAX wardrobes with high-gloss surfaces. Due to daily use, fingerprints, dust, and minor stains quickly accumulate, but I’ve read that aggressive cleaners can damage the surface. My question is: What is the gentlest way to clean Ikea PAX high-gloss surfaces to maintain their shiny appearance while avoiding scratches or dull spots? Are there any recommended cleaning products or home remedies, or special cleaning techniques I should keep in mind? I would prefer not to spend a lot of money but still want to keep the surface well maintained for a long time. Thanks for your advice!
Edric
19 May 2020 10:13
I understand your concerns about damaging the surface. High-gloss finishes are impressive, but that also makes people worry about small scratches. In my experience, working carefully with a clean microfiber cloth and lukewarm water is often sufficient. Using gentle cleaning agents and then buffing lightly afterward can provide extra reassurance. And if something does go wrong, polishing again with a very soft cloth without applying pressure helps. This way, cleaning stays calm and controlled.
semuneo
19 May 2020 18:05
I also have Pax high-gloss, and I notice that fingerprints tend to show up easily. What helps me is frequently washing the microfiber cloth to avoid rubbing small particles into the surface. What I find very important: no alcohol or other harsh cleaners, as they damage the finish. If something is stuck, it’s better to lay a damp cloth on it for a few minutes and then gently wipe it off.
Hausu
20 May 2020 07:55
semuneo schrieb:
No alcohol or other aggressive cleaning agents, as they damage the finish.
Good info, thanks! I actually once tried to remove a stain with rubbing alcohol, and it didn’t go very well. I’ve also read that even citric acid can be harmful. Is there anything specific you should definitely avoid when caring for Ikea PAX high-gloss surfaces? Does anyone have experience with traditional household remedies like vinegar or baking soda—are they safe to use at all, or should they generally be avoided?
