ᐅ How can I gently clean IKEA Hemnes furniture in a home with pets?
Created on: 8 Nov 2020 08:17
MUGI47
MUGI47
8 Nov 2020 08:17
I have a question about the best way to clean IKEA Hemnes furniture, especially when pets live in the household. Since my cat often lies on the furniture and sometimes leaves small paw prints or stains, I want to know how to clean the surfaces gently and effectively without damaging the wood or affecting the finish.
Are there specific cleaning products or home remedies that work well? And how often should the furniture ideally be cleaned to protect the surfaces while keeping them hygienic?
I look forward to practical, experience-based tips and advice on caring for the Hemnes series in a pet-friendly home. Thanks in advance!
sihau
8 Nov 2020 08:45
For cleaning IKEA Hemnes furniture in households with pets, I generally recommend using mild cleaning agents without harsh chemicals. The furniture is usually made of lacquered pine wood with an open-pored surface, which is prone to scratches and moisture damage.
- Use a damp microfiber cloth to remove dust and light stains.
- For stubborn dirt, a mild soap solution (neutral pH) is suitable.
- Avoid abrasive sponges or alcohol-based cleaners that can damage the lacquer.
- Thoroughly dry the surface after cleaning.
Cleaning about once a week or whenever visible dirt appears is advisable to prevent dirt from setting or becoming embedded.
rubybi
8 Nov 2020 09:22
I would like to add a more detailed response.
First of all, it is important to know that IKEA Hemnes furniture is usually made from solid pine wood, sealed with a clear lacquer. This coating protects the surface but is sensitive to strong cleaning agents and mechanical stress. Therefore, cleaning should always be done gently and preventively.
Step-by-step cleaning guide for homes with pets:
- Cleaning dust and light dirt: A dry or only slightly damp microfiber cloth works best. This prevents moisture from penetrating the wood.
- For stains or paw prints: Prepare a mild solution of warm water and a few drops of unscented, mild dish soap without aggressive additives. Dip the cloth, wring it out very well, and wipe the affected areas.
- Avoid using vinegar, alcohol, bleach, or ammonia, as these can damage and fade the lacquer finish.
- After cleaning, always wipe the surface thoroughly with a dry cloth to remove any remaining moisture.
Tip: Since pets can also cause small scratches with their claws, I recommend regularly checking the furniture for small areas with damaged lacquer and touching them up as needed with a suitable furniture repair marker.
Summary: Mild, moist cleaning, no harsh chemicals, thorough drying, and regular inspection will help preserve your Hemnes furniture in the long term.
rigau
8 Nov 2020 10:37
Simply dampen a cloth, clean with mild dish soap, then wipe dry. Do not use harsh cleaners or alcohol!
Nadine
8 Nov 2020 11:15
I would like to add that especially for pets, odorless cleaning products are advisable to avoid disturbing the animals. Additionally, I recommend against polishing furniture with strong pressure, as this can damage the surface.
It is also helpful to regularly trim the claws of cats or dogs. This reduces scratches on the wood. Placing blankets or covers on heavily used areas of furniture can make cleaning easier and provide extra protection for the surfaces.
MUGI47
8 Nov 2020 12:03
sihau schrieb:
Avoid abrasive sponges or alcohol-based cleaners that can damage the finish.
Thank you for the advice, I wasn’t aware of the issue with alcohol-based products. My household cleaner often contained alcohol.
I’m also interested in tips for protecting furniture when mechanically removing pet hair or dirt, for example, without scratching. Are there specific tools or techniques for this?
