ᐅ How do I fix wobbly MALM nightstands?
Created on: 1 Apr 2016 08:43
tayfun
tayfun
1 Apr 2016 08:43
I own several MALM nightstands from IKEA that have become wobbly after some use. The design consists of the main body with a drawer, standing on four legs, which seem to have become unstable. My problem is that the wobbling doesn’t come from just one side but is somewhat irregular, making the nightstand feel unsafe.
My question is: How can I effectively and as permanently as possible fix the wobbliness of the MALM nightstands without having to completely disassemble them or buy new parts? I’m looking for practical, DIY tips that are easy to apply and will stabilize the furniture in the long term.
GLALEO
1 Apr 2016 10:12
It’s great that you described the problem in such detail! 🙂
First, you could check if the screws on the legs or joints are loose. Often, wobbling is caused by loose connections. I once removed the legs from my MALM bedside table and reinforced the threads with some all-purpose adhesive, which held really well!
Also, sticking small self-adhesive felt pads under the legs can work wonders if the floor is uneven!
The important thing is: keep at it and take small steps – every loose point you fix adds more stability. And once you see how well it works, repairing becomes really enjoyable! 🙂
bupar
1 Apr 2016 12:34
The wobbling stability of MALM nightstands is often related to the design of the legs and the attachment of the drawer front. A professional solution involves:
1. Systematically check all screws for tightness, especially on the legs and drawer slides.
2. If the threads are stripped, you can reinforce the screw holes using wood glue and toothpicks.
3. If the floor is uneven, raise or level the legs with adjustable furniture levelers available at hardware stores.
4. Avoid overtightening the screws, as this can damage the screw holes.
These steps maximize stability with minimal effort and without complicated disassembly.
tayfun
2 Apr 2016 09:17
GLALEO schrieb:
Thread stabilized with some multi-purpose adhesive, it held really well!
That’s an interesting approach. Did you just apply the multi-purpose adhesive directly into the thread? How exactly did you proceed to screw it back in afterward? Does the adhesive cure quickly, or should it be done slowly to properly fit the screw?
bupar schrieb:
Wood glue and toothpicks to reinforce the screw holes.
That also sounds sensible. I assume this method is helpful when the thread is completely stripped?
Thanks in advance for the practical tips. I will probably try the screw fastening and stabilization first, and then level the feet with felt pads if the floor is uneven.
nikian
3 Apr 2016 14:52
I would like to add that with MALM nightstands, it sometimes happens that the metal fittings securing the drawers can be slightly bent or worn out, which makes the entire piece of furniture feel unstable.
In detail:
- Check whether the metal brackets on the inside of the nightstand are properly positioned and if any screws are missing.
- Minor adjustments with pliers or tightening the screws can help reduce the problem.
- Additionally, drawer stops or small self-adhesive bumpers can help minimize tilting.
However, the most important point, as already mentioned, is the screw connections and the anchoring of the legs. If these are secure, most of the issue is resolved.
Good luck with the repair, you can definitely do it! 🙂
