I am currently considering how to make my IKEA Malm chest of drawers safer and more stable, as it is heavily used in my bedroom. The drawers operate smoothly, but I have noticed that the side panels and the back panel flex slightly under load. My question is: Is it possible to reinforce a Malm chest of drawers with reasonable effort, without having to completely disassemble or extensively modify it?
I am particularly interested in experiences or tips on how to strengthen the structure using simple methods (e.g., wooden strips, special brackets, metal profiles) to make it more durable and capable of handling heavier loads. Are there any known weak points that should be addressed specifically?
Thank you in advance for your opinions and advice!
I think the whole fuss about the Malm is a bit overblown. For the price, the piece is perfectly acceptable in terms of design. Of course, if you expect a massive wardrobe system, you will be disappointed.
Sure, the back panel made of fiberboard isn’t very sturdy, but looking at it from just that perspective is naive. If you handle your furniture with care, you might not need any reinforcement.
I suggest simply accepting that a piece of furniture in this price range doesn’t have an extremely long lifespan, and you either buy a new one or modify it completely if you want something more durable. Just adding corner braces is often just a placebo. 😉
SIAURORA schrieb:
If you always handle the furniture carefully yourself, you might not need reinforcement.There is some truth to that, but not everyone has the patience or motivation to be 100% careful—especially with children or pets around. 🙂
Still, I see small reinforcements as a kind of insurance: a little effort makes you feel more secure and allows you to use the dresser more freely. Plus, it’s fun to spruce up the piece and make it sturdier.
In the end, everyone has to weigh the cost and effort themselves, but it’s not that complicated.
SIAURORA schrieb:
Just adding brackets is often just a placebo.May I disagree? When the brackets are properly selected and professionally installed, they can significantly improve the torsional stiffness of a dresser. Of course, this does not replace a solid frame, but the purpose is to stabilize the construction, not to reinvent it.
Anyone using the Malm dresser should know that it is made of particleboard and corrugated cardboard, so it won’t become a rustproof metal-frame structure.
Therefore, I see the use of brackets as a practical solution without expensive furniture production. A few tips:
- Always use countersunk screws with brackets
- Adjust screw length according to the wood
- Pre-drill to prevent splitting
Just a quick summary in case it helps anyone here.
I completely replaced the back panel of my Malm with a thin plywood board and attached metal profiles on the inside of the sides. This greatly improved the stability, but I had to partially empty and disassemble the dresser to do it.
If you need a quick solution, small brackets in the inner corners are sufficient. Simple and effective.
Thank you very much for the many helpful responses and different perspectives!
Let me summarize:
- The back panel is a weak point; plywood as a replacement or additional layer has advantages.
- Angled brackets at the edges increase torsional stiffness.
- Screw length, pre-drilling, and wood glue are important to avoid damage.
- Completely unscrewing is possible but often not necessary.
- Depending on usage and care, the necessity may vary.
I will take the opportunity to tighten screws, order additional brackets, and consider whether to simply reinforce the back panel or only add brackets.
One more question for the experienced craftsmen here: Is there a recommended material thickness for the plywood sheet you would suggest for the back panel? Should I use 3 mm (0.12 inches) or go a bit thicker to add more stability without warping the whole dresser?
Let me summarize:
