ᐅ How can I fix problems with squeaky Ikea Metod hinges?
Created on: 30 Mar 2020 09:27
Kazim
Kazim
30 Mar 2020 09:27
For the past few weeks, we have been experiencing an issue in our kitchen where the doors of the Ikea Metod cabinets squeak unpleasantly whenever they are opened or closed. This affects several hinges, especially on the upper and lower doors. I have already tried readjusting the hinges, but the squeaking noise persists.
Since the hinges are made with a metal-plastic combination that typically should not require lubrication, I am wondering where the problem might be exactly.
My goal is to find out how to permanently eliminate this typical squeaking noise, and what kind of maintenance or measures are advisable without potentially compromising functionality or design.
Do you have any experience with squeaking Ikea Metod hinges? What products or tricks have worked for you? Is it sufficient to oil or grease the hinges, or should other maintenance steps be taken?
Thanks for your tips and advice!
stefangla
30 Mar 2020 11:03
Hello Kazim,
First of all, that’s a commendable question with good attention to detail! Squeaky Ikea Metod hinges are indeed a common issue, and there are a few points to consider before simply applying lubricants.
Here’s my structured approach:
- Cause analysis: Often, the squeaking is due to too much or too little play or contamination within the hinge mechanism.
- Cleaning: Start by thoroughly removing dust, crumbs, or residues from the hinges. A lint-free cloth or a cotton swab works well for this.
- Lubrication: For Ikea Metod hinges, I recommend a specialized silicone oil or Teflon spray, as these are non-sticky and don’t attract dirt. WD-40 can provide short-term relief but is not a long-term solution.
- Application: Apply lubricant sparingly and only to the moving metal parts, taking care to avoid contact with wood or paint.
- Function check: After lubricating, open and close the door several times to distribute the oil evenly.
- Adjustment: If the doors do not close flush, a small adjustment of the hinges can also reduce the squeaking.
Common mistakes include applying too much oil or using grease-based products, which attract dust and can worsen the problem.
Summary: Cleaning, targeted use of dry or silicone oils, and adjustment.
I hope this helps. Feel free to ask if you need more detailed tips on adjusting the hinges.
Taylorsi45
30 Mar 2020 14:19
stefangla schrieb:
Apply lubricant only sparingly to the moving metal parts, making sure it does not get on the wood or paint.
Exactly. Use silicone spray, not WD-40. Clean the hinge beforehand. Nothing more is necessary.
Kazim
31 Mar 2020 08:52
stefangla schrieb:
For Ikea Metod hinges, I recommend a special silicone oil or Teflon spray, as these are non-sticky and do not attract dirt.
Thank you for the detailed response; that sounds very helpful. I’m also curious if anyone has experience with how often the hinges should actually be lubricated? Is there a sort of maintenance interval, or does it strongly depend on usage and environment?
Additionally, I wonder if it is possible to completely replace the Metod hinges with other models that offer better noise insulation. Does anyone know of compatible alternatives that prevent this squeaking effect from the start?
Thanks in advance for any additional tips and information!
