ᐅ How do I fix a loose IKEA Metod drawer?
Created on: 22 Jun 2020 18:37
Beyoshua
Beyoshua
22 Jun 2020 18:37
I have a problem with a drawer from the IKEA Metod kitchen system that has recently become quite loose and wobbles significantly when opened and closed. The drawer is not completely off its track, but it no longer sits firmly in the runners, which obviously makes handling unpleasant. So far, I haven’t disassembled the drawer completely because I’m unsure which parts I should specifically check or replace.
Does anyone have a detailed guide or at least some tips on how to reliably repair a loose-fitting IKEA Metod drawer? It would be especially helpful to know how to tell whether the rollers or the runners are defective or just misadjusted, and how to properly readjust or replace them if necessary.
I have moderate DIY skills, so a step-by-step explanation or pointers on important aspects would be appreciated. Thanks in advance!
Alberto51
22 Jun 2020 19:46
Beyoshua schrieb:
Does anyone have a detailed guide or at least tips on how to reliably fix a loose-fitting IKEA Metod drawer? What’s especially important for me is how to tell whether the wheels or the drawer slides are damaged or just misadjusted, and how to properly readjust or replace them if necessary.
I know exactly how frustrating these wobbly drawers can be—I’ve dealt with the same issues in my Metod kitchen. What helped me was first patiently removing the drawer completely and carefully inspecting all the moving parts.
Sometimes it’s just the plastic rollers that have become worn or slightly damaged from regular use. If they look brittle or unevenly worn, it’s usually better to order replacement rollers and swap them out instead of trying to fix the old ones.
If the slides are loose, I tightened the screws—on some models the screw holes in the cabinet frame are pre-marked, but during assembly they can easily shift a bit.
I also think it’s important, when reinserting the drawer, to make sure the slides are perfectly aligned; otherwise, you can easily cause the drawer to wobble.
I understand that this kind of thing can feel overwhelming, but with some patience you’ll usually succeed. If you want, I can check whether I still have my old spare parts list and give you exact part names.
Hope this helps a bit!
TEBILO
23 Jun 2020 08:14
Alberto51 schrieb:
If the tracks are loose, I tightened the screws – with some models, the screw holes on the cabinet are pre-marked, but during assembly, things can easily shift.
I’d like to focus on this point in more detail because there are actually some technical nuances with IKEA Metod drawers that are often underestimated. I follow three steps when a drawer feels loose:
- Remove the drawer: First, detach the front panel if necessary. Metod drawers usually come with metal runners that are easy to remove.
- Check for tension: Inspect the runners on both the cabinet and the drawer base. Loose screws can noticeably affect how smoothly it slides. Make sure to systematically tighten all screws.
- Condition of the drawer slides (metal or plastic rollers): Plastic rollers tend to wear out. If they become brittle or don’t roll smoothly, you’ll notice wobbling or slight sideways movement. Replacement parts are readily available from IKEA; the part number for rollers is, for example, 992.377.53 (depending on model and production year).
Another tip: Dust or small debris can accumulate inside the runners, which slows down the drawer and increases the feeling of looseness. Using a fine brush or compressed air can make a big difference.
One more thing I always check on Metod drawers is the “soft-close” mechanism. In some models, it may be damaged, which can also indirectly cause wobbling. Running the drawer without soft-close can provide useful clues.
If you want, feel free to send me the exact model number of your Metod drawer, and I can help you find matching replacement parts or further advice more precisely.
Overall rule: Carefully disassemble and reassemble everything, and you will usually find the root cause.
LAURE-TA
24 Jun 2020 11:52
Beyoshua schrieb:
I have average DIY skills, so I would appreciate a step-by-step explanation or tips on important points.
I have put together a short guide to help you repair your loose IKEA Metod drawer:
1. Fully pull the drawer out of the cabinet and place it on a stable work surface.
2. Carefully remove the front panel (depending on the model, this may be done using hidden screws or clips).
3. Closely inspect the plastic rollers or metal slides for wear, cracks, or deformation.
4. Check the screws on the drawer slides with a suitable Phillips screwdriver and tighten them if necessary.
5. If any rollers are damaged, have replacement rollers ready (identify the correct part based on the model number online or in the manual).
6. Clean the slides from dirt and dust; if needed, wipe them with a dry, lint-free cloth.
7. Reinsert the drawer, making sure the slide mechanism is properly aligned — there are often visible locking points.
8. Test whether the drawer now runs smoothly and no longer wobbles.
I recommend not using excessive force, especially when removing the front panel, as the attachment points are often fragile.
If in doubt, consult the assembly instructions for the Metod system — some IKEA models vary slightly in mechanism and fastening.
Good luck!
Le-so
24 Jun 2020 13:27
LAURE-TA schrieb:
Carefully inspect plastic rollers or metal guides for wear, cracks, or deformation.
- Replace rollers if they are damaged.
- Tighten screws.
- Remove dirt.
- Hang the drawer correctly.
Done.
