ᐅ How can I efficiently install Ikea Metod cabinets in small kitchens?
Created on: 14 Aug 2024 08:37
Nirobi
Nirobi
14 Aug 2024 08:37
Hello everyone, I am facing the challenge of setting up Ikea Metod cabinets effectively and space-efficiently in a particularly small kitchen. Due to the limited space, I want to avoid losing too much room to unused cabinet surfaces. My kitchen is only 2.20 meters (7 feet 3 inches) wide with a standard depth of 60 cm (24 inches). Additionally, I want to maintain functionality, so enough storage space and a smooth workflow are essential.
I am especially interested in how to sensibly combine different cabinet sizes and interior fittings, and what tips there are for optimizing corners or narrow niches. Which options (e.g., corner cabinets, tall cabinets, wall cabinets) make the most sense? Does anyone have experience with custom solutions within the Metod system to really maximize small kitchens?
I appreciate any advice, especially proven setups or specific recommendations for adapting to tight kitchen spaces. Thank you!
Lorukeo
14 Aug 2024 10:42
For efficient use of small kitchens with Ikea Metod, I recommend the following points:
- Use corner cabinets with carousel or LeMans pull-outs for optimal access in tight corners.
- Opt for tall cabinets to make the most of vertical space, especially when the floor area is limited.
- For very narrow gaps, slim pull-out cabinets (e.g., 15 cm (6 inches) wide) are ideal for spices or bottles.
- Interior fittings like pull-out organizers, multi-level drawers, or adjustable shelves provide flexible space usage.
Precise planning with the Ikea planner is also essential to adjust measurements exactly and test combinations early. It is also advisable to choose light colors for the fronts to make the space appear larger and more open.
These standardized solutions are easily adaptable without resorting to custom-made options.
PeoDaniel
14 Aug 2024 13:22
I support the recommendations and would like to add:
- Use wall cabinets up to the ceiling whenever possible. This creates additional storage space for items that are used less frequently.
- Installing mounting brackets or extra wall shelves next to Metod cabinets can provide additional space in small kitchens.
- Pay attention to good ergonomics during installation: the height of work surfaces and the distances to the stove and sink should be appropriate.
Lorukeo schrieb:
Use corner cabinets with carousel or LeMans pull-out fittings for optimal access in tight corners.
This is especially important because without practical corner solutions, cabinets often remain inaccessible and become storage for forgotten appliances or supplies.
If you like, you can also directly ask the Ikea Metod department about special features; they often have small accessories that are not immediately obvious.
nolan
15 Aug 2024 09:05
For small kitchens, the following applies:
- Always choose corner cabinets with a carousel or pull-out trays.
- Use tall cabinets to maximize height.
- Narrow pull-out cabinets work well as gap fillers.
- Use the IKEA planner beforehand.
lyndon
15 Aug 2024 17:53
A brief addition on the topic of efficiency when installing Ikea Metod kitchen units in small kitchens:
Apart from choosing the right cabinet modules, the most important factor is precise space measurement before purchase. Even a few centimeters (inches) of deviation can cause problems when fitting cabinets perfectly without gaps. I recommend particularly checking the floor and walls for irregularities – often heating pipes or slightly uneven walls can be an issue.
In addition, modular internal organizers can be used to maximize usable storage space. For example: metal cutlery trays with raised sides, small shelves for spices, or flexible baskets that can be customized individually.
Nirobi schrieb:
I am especially interested in how to sensibly combine different cabinet sizes and interior fittings, and what tips there are for making the best use of corners or narrow niches.
When it comes to combination, planning accuracy is essential – write down all measurements, check for door and drawer overhangs, and consider access in tight spaces. These details determine whether you’ll be satisfied after installation or need to do further adjustments.
