ᐅ How can I customize IKEA BESTÅ drawers with individual inserts to improve organization?
Created on: 23 Jun 2021 09:37
Deo53Hello everyone, I have a somewhat more specific question regarding organization in IKEA BESTA drawers:
How can I arrange IKEA BESTA drawers with customized inserts for organization so that the existing storage space is used as efficiently as possible and various items – from documents to small parts and electronic accessories – are well organized and at the same time easily accessible?
I am particularly interested in which types of inserts or divider systems work best for this, whether it is better to use standardized solutions or DIY options, and how you might adjust the drawer interior (materials, dimensions, etc.) to tailor the organization perfectly to your individual needs.
I would appreciate practical tips, experiences, or warnings about potential pitfalls in the design process, so I don’t have to redo everything multiple times. Thanks in advance!
Your question is very well formulated and covers essential aspects.
As a general recommendation, start with a detailed inventory: What exactly should go into the drawers? How much space does each item require? From this, you can determine whether adjustable inserts make sense or if modular compartments are better.
For IKEA BESTA, I often use the narrow dividers that can be placed flexibly, combined with small plastic or felt boxes to group small items.
Standardized inserts, like those from IKEA, are practical if the dimensions fit and the height of the items is considered. For electronic components, for example, the compartments should be slightly deeper and lined with padding to prevent damage.
DIY inserts made from wood or sturdy plastics offer more flexibility but require craftsmanship skills and precise measurements. Depending on how much time and effort you want to invest, this can be worthwhile.
Also important: Pay attention to the maximum load capacity of the drawers to avoid overloading.
Another tip: Sometimes it is better to create a removable insert that can be completely taken out when you need quick access to items stored further back, rather than having many small fixed compartments.
If you can provide specific measurements or examples, I could help you more precisely.
praWarre6923 Jun 2021 12:45Hey Deo53, great topic! The IKEA BESTA shelf system is really versatile, especially when it comes to the drawers.
A quick tip from my experience: try using foam inserts – they’re really easy to customize with a utility knife and also provide some cushioning, which is perfect if you want to organize delicate items like chargers, USB sticks, or other small gadgets 😉
- Advantage: DIY feel and completely custom
- Disadvantage: Requires patience for measuring and cutting
I also find those small bamboo or cardboard boxes that you can simply place inside the drawer quite useful. They add a bit of natural look, if that appeals to you.
Otherwise, try using labels – visual organization really helps with quick identification.
By the way, what kind of “small parts” are you looking to sort? Maybe we can offer more targeted advice.
Hello Deo53,
I would like to address your question and provide some technical details that, in my view, are important when customizing IKEA BESTA drawers.
First: The internal dimensions of the standard BESTA drawers are usually around 58 x 38 x 15 cm (WxDxH), but they vary depending on the model. When selecting or creating inserts, it is important to strictly adhere to these tolerances, especially if you plan to use modular inserts or DIY partitions made from plywood or MDF panels.
Second: For different uses, a combination of various compartment heights is recommended. Shallow compartments work well for documents and writing materials, while deeper ones are suitable for cables, chargers, and other electronic components. Foam or felt inserts with adjustable depth can be considered here.
Third: To secure the inserts, I suggest either screwing rails in place or using clamping mechanisms (e.g., small magnets) to prevent shifting when opening and closing the drawer.
Fourth: Materials like acrylic (Plexiglas) or sturdy plastics are suitable for making transparent and durable inserts. This helps keep an overview and prevents visual clutter.
Regarding your question about DIY versus standard options: my advice is a hybrid approach—fixed partitions for larger sections and custom-cut inserts for flexible areas.
What specific applications are you planning? Do you need, for example, decoupling of electronic components or special sound isolation for acoustic equipment? These details could be crucial.
lorena schrieb:
For different applications, a combination of various compartment heights is recommended.This is an important point. Planning different heights within a single drawer is often underestimated.
What I would also like to add: For sensitive electronic items, it can be beneficial to use antistatic materials in certain inserts to prevent static discharge that could cause damage.
Sometimes it’s also worthwhile to create special “reserve compartments” for particularly important items, which are only opened when needed, so everything doesn’t get mixed up.
In general, as you write, combining different types of inserts and heights is the most effective approach.
For a more organized use of IKEA BESTA drawers, I recommend clearly prioritizing storage space based on how frequently items are used:
- Frequently used items should be stored within ergonomic reach and with maximum visibility.
- Less frequently needed items can be placed in deeper, enclosed inserts that protect against dust and damage.
For implementation:
- Flexible plastic divider systems allow adjustments to changing needs.
- Flat inserts with easy-to-pull-out trays are suitable for documents.
- Organization systems with different module sizes support adaptation to various item sizes.
Additionally, I suggest regularly reviewing and adjusting the organization to keep the system functional over time.
A combination of modular inserts and a fixed base layout has proven to be particularly effective.
For implementation:
