ᐅ How do I properly assemble an Ikea Pax wardrobe system?
Created on: 26 Jan 2015 16:07
Marjanni34
Marjanni34
26 Jan 2015 16:07
Hello everyone, I am planning to assemble an Ikea Pax wardrobe system, but I have a few uncertainties about how to do it correctly and, above all, securely. Specifically, I want to know how to properly connect the individual modules, which steps are especially important when joining the carcass frames, and what I need to pay attention to so that the wardrobe not only fits visually but also stands safely—especially regarding wall mounting and door alignment. Are there any special tips or tricks I should keep in mind when assembling the Pax wardrobe to avoid mistakes? I would appreciate detailed advice, particularly from anyone with experience in more complex Pax configurations. Thank you in advance!
benonon
26 Jan 2015 18:23
Hello Marjanni34, I completely understand your concerns, as installing a PAX wardrobe system does involve several important points that should not be overlooked. I will go through the key aspects step by step:
- First of all, it is essential to carefully check and count all parts before starting the assembly to avoid interruptions later on.
- The carcasses are connected using the supplied dowels and screws. It is crucial to ensure precise alignment so that the wardrobe stands stable and straight.
- It is best to use a spirit level during every assembly step to immediately correct any slight deviations. This is especially important when multiple modules are placed side by side.
- For wall mounting, special brackets are provided. Depending on the wall type (concrete, drywall), appropriate anchors should be used to ensure load-bearing capacity.
- When attaching the doors, slight adjustments are possible. The hinges allow you to align the doors so that they close flush.
If you let me know which PAX modules or sizes you plan to install exactly, I can provide more specific advice on particular challenges.
In general: take your time and check the stability after each major step. The effort is worth it for a durable and functional wardrobe system.
V
vinli
27 Jan 2015 09:54
As a supplement and a precise guide, I recommend the following systematic approach for assembling the Ikea PAX wardrobe system:
- First, plan the assembly including the room layout and the wardrobe’s orientation. Clear the area to provide enough space and protection for the components.
- Start by assembling the individual carcass frames, which are connected using cam fittings and wooden dowels. Make sure to insert the dowels properly and fully tighten all screws.
- Connect the carcasses using the included connector fittings. Use a sturdy workbench or flat surface for alignment.
- Before fixing the wardrobe to the wall, check that the wall is square and load-bearing. Use appropriate anchors, such as heavy-duty anchors for concrete or metal anchors for drywall.
- Use a spirit level and a tapping block to avoid damage and ensure precise alignment. Wall fastenings secure stability against tipping.
- Door hinges can be adjusted afterward; make full use of this feature. The doors can be perfectly aligned after assembly.
- Finally, check all connections again to ensure they are tight.
These steps ensure a safe assembly of your PAX wardrobe system. Read the Ikea instructions carefully beforehand, but following this approach will keep you on the safe side.
suru61
27 Jan 2015 15:32
That’s a great question, Marjanni34!
Marjanni34 schrieb:
how to properly join the individual modules, which steps are especially important when connecting the cabinet frames, and what to watch out for
In short: Patience is your best friend during assembly. If you work methodically and treat each step like a small puzzle, the PAX will bring you real joy.
Here are a few tips I used during my assembly back then:
- Lay out all the parts sorted on the floor first, so you can find them more quickly.
- When joining the cabinet boxes, pre-drilling is unnecessary, but carefully inserting the dowels is invaluable.
- And honestly: Having a second person is priceless! It saves nerves and even makes it more fun. 😄
vinli schrieb:
Use a spirit level and a mallet to avoid damage and ensure precise alignment.
I fully agree with that – especially alignment is key to enjoying the finished wall cabinet—nothing wobbles and no doors get stuck all the time. And by the way: Don’t forget to attach the wall profile solidly and securely; it’s the backbone of your PAX tower!
Good luck, and feel free to ask if you have any questions along the way!
NoValentin
28 Jan 2015 08:11
Briefly to the point:
- Dimension the components
- Connect the carcass with dowels
- Screw carcasses together using connectors
- Use a spirit level and wall fixings
- Adjust the doors
Done. Everything is stable and secure if you follow this sequence.
