ᐅ How can I combine Ikea Besta units with natural wood fronts?
Created on: 16 Mar 2018 09:37
blape
blape
16 Mar 2018 09:37
Hello everyone, I am currently exploring how to combine Ikea Besta carcasses with natural wood fronts. My goal is to create a cozy atmosphere that preserves the modular character of Besta while adding warmth and naturalness through the wood finish. My question is:
How can I best connect natural wood fronts with Besta both stylistically and practically? What should I consider regarding the material or surface treatment to ensure the overall look is harmonious and durable?
I would also appreciate tips on color combinations, optimal care for the fronts, or mounting methods. I have seen that many users replace or supplement the fronts themselves, but it is important to me that the installation remains simple and that the wood is not coated with too much paint or plastic, as I want to maintain its natural quality.
Looking forward to your experiences and recommendations!
LANICOLE
16 Mar 2018 10:45
blape schrieb:
How can I best combine natural wood fronts stylistically and practically with Besta?
That’s a good starting question. Here is a clear five-step approach:
- Material choice: Solid wood or wood veneer with a thin protective layer works best, as it showcases the natural texture.
- Color matching: Choose wood tones that either match the color of the Besta cases (usually white or anthracite) or deliberately create contrast, for example, light oak with black or white.
- Surface treatment: A natural oil or wax finish preserves the feel, instead of thick lacquer which can appear artificial.
- Installation: Ikea Besta has standardized dimensions, so it’s helpful to have ready-made fronts cut to size or custom-made by a carpenter. There are mounting systems that allow tool-free replacement.
- Maintenance: Regular cleaning with mild products and re-oiling of oiled wood keeps the fronts looking good over time.
Tip: Make sure the wood isn’t too thick, as Besta office flaps and hinges have limited tolerances.
If you have any questions about implementation, feel free to ask.
draleo
17 Mar 2018 08:29
blape schrieb:
I have seen that many users replace or add the fronts themselves, but for me it is important that installation remains simple and that the wood is not coated with too much paint or plastic, as the natural look should be preserved.
From a technical perspective, I recommend the following:
- Purchase wood fronts that are specifically designed for Ikea Besta. These are dimensionally accurate and often have a surface treatment with natural oil instead of paint.
- If self-construction or modification is planned, the wood thickness should be limited to a maximum of 18mm (0.7 inches) to protect the hinges.
- Generally, oiled or waxed wood is better than painted wood because it remains breathable and retains its character.
- For easy installation, clamping or screw systems are recommended that do not interfere with the original Besta hinge mechanism.
- Color combinations: A natural light wood tone pairs well with white Besta carcasses, while darker woods work nicely with anthracite.
It is important that the wood fronts are flat and have edges that are properly chamfered or rounded to avoid friction when opening.
blape
17 Mar 2018 16:12
LANICOLE schrieb:
There are fastening systems that allow tool-free replacement.
That sounds interesting – could you describe these systems in more detail? I ask because I want to stay visually flexible and avoid constantly having to screw on new fronts.
Also: Does anyone have experience with the long-term stability of oiled wooden fronts in kitchens or living rooms? I assume the maintenance is more intensive than with lacquer, but I’m willing to accept that as a compromise.
draleo schrieb:
For simple installation, clamp or screw systems are suitable, which do not interfere with the original Besta hinge insert.
I’ll take a closer look at that as well. Thanks for the tip!
One additional question: Is it possible to oil the wood afterwards to change its color, for example, to achieve a darker shade, or would that be problematic in terms of durability?
Looking forward to your advice!
